Z06 is shutting down - Z06Vette.com - Corvette Z06 Forum
post #1 of 5 (permalink) Old 06-14-2016, 02:37 PM Thread Starter
Desertstormvet's Avatar
Send a message via AIM to Desertstormvet
Has anyone had problems with the motor shutting off? No dash indicators light up, but still has power to lights stereo etc...It's at the dealer for 2 weeks now and they are still scratching their heads. They thought a fuel pump relay. Any info would be great!
Desertstormvet is offline
post #2 of 5 (permalink) Old 06-15-2016, 08:00 PM
Z06 Tech Advisor
racingvette's Avatar
Re: Z06 is shutting down
Check for bad or loose grounds
Check the oil pressure sensor, if defective and reports low oil pressure the PCM will shut down the engine to save it from damage
Mike M - 2001 / 2008 Z06s
racingvette is offline
post #3 of 5 (permalink) Old 11-21-2016, 08:19 AM
Thank you very much I am running out of ideas and appreciate the feedback
sohara is offline
post #4 of 5 (permalink) Old 11-22-2016, 12:23 AM
I had a friend that had a fuel pump relay go bad. Dealer changed out the fuel pumps only to find out it was the relay. Was a very costly mistake.
jub jub is offline
post #5 of 5 (permalink) Old 11-23-2016, 06:27 PM
Thanks again I am learning more as time goes on. Started out when I got the check charging system. Changed the alternator then starter as they are connected and all was good. Battery about 4 months old it's an AGM type. Anyway when started 14.2-14.5 volts and car runs great. I found out yesterday that after the car is driven and restarted something pulls the voltage down to 13.6 to 13.8 falling below what is needed to run the ignition and injectors it seems. I don't know what it is fans make sense but the car runs great with the fan until turned off. I guess I need to take it in and have diagnostics identify the part. Love the car, had the heads swapped out two years ago and it's awesome. Dying tune has 497hp and similar torque at the wheels. Also love the non run flat Michelin ps2's. love the forums they always help me
sohara is offline
  Z06Vette.com - Corvette Z06 Forum > C6 Z06 Specific Topics > C6 Z06 - Grandstand
Rattle when shutting the car off. Scotty-ZO6 C5 Z06 - Grandstand 11 01-26-2010 10:37 PM
The Clunk noise when shutting down donmet C5 Z06 - Pit Road 14 08-24-2005 10:40 AM
Grinding noise when shutting down without clutch HeadHunter C5 Z06 - Pit Road 10 10-01-2003 05:14 PM
My car won't idle and keeps on shutting off Special C5 Z06 - Tuning & Electronics 4 08-03-2003 09:04 PM
