Old 08-26-2008, 06:38 PM   #1 (permalink)
blackvetterzo6's Avatar
1st and 2nd gear hesatation when cold
Car runs a little rough until oil warms up.Is this normal? And whats the reasoning for the hesatation until warm? When oil hits about 85 she runs great.Diablo tune and k&n intake. No leaks in the intake. LTFT's dialed in almost perfect.
Thanks guys.
blackvetterzo6 is offline   Reply With Quote
Old 08-26-2008, 06:46 PM   #2 (permalink)
Re: 1st and 2nd gear hesatation when cold
sorry guys ment to put this in c-6 z06. But it should be about the same answer i would think.
Old 08-26-2008, 08:24 PM   #3 (permalink)
C_U_LATER_ZO6's Avatar
i used to have a similar problem when i had my evo, 1st and 2nd would rattle a little and just the smallest noise, but the SYNCHROS were starting to go but when the oil warmed up it went away, so u might look into that, and possibly oil slip and its not circulating thru gears properly, jus some suggestions, good luck with it man
C_U_LATER_ZO6 is offline   Reply With Quote
Old 08-26-2008, 08:26 PM   #4 (permalink)
sorry meant to put (a little rough), not rattle.
Were You Cold Art?? TexasBlue72 The Garage 17 11-28-2005 08:00 AM
Motive Gear 3.73 Gear Ratio Shortage Dynotech Eng. C5 Z06 - Pit Road 4 02-18-2005 08:48 AM
3rd gear/steel shift fork/now 4th gear! MSiska C5 Z06 - Pit Road 14 07-23-2003 07:01 AM
How cold is to cold? MARZ06 C5 Z06 - Pit Road 5 07-01-2002 11:13 AM
Got a BAD cold!!! Rick1 The Garage 6 12-23-2001 09:40 PM
