Old 03-02-2008, 06:05 AM   #1 (permalink)
jrhunkler's Avatar
2008 Z06 Shift Problem
Gears grind bad from 1st to 2nd. I spoke to some other Z06 owners that told me its a known issue, and that they have had their clutch, and/or "synchros" repaired several times under warranty. Anyone know about this in here?
jrhunkler is offline   Reply With Quote
Old 03-02-2008, 08:40 AM   #2 (permalink)
Re: 2008 Z06 Shift Problem
It's only happened to me w/ my o8 twice. Both times I was cranking and I think it was more me than the car. I felt it was my clutching and or shifting. I haven't had that happen under normal or even somewhat hard acceleration.
Old 03-02-2008, 03:22 PM   #3 (permalink)
I noticed that the shifter is a bit clunky when cold, but when warm, it's fine. Just don't start bangin' til it warms up...
George B.
* '08 JSB Z06 11.4 @ 126 on EMTs, 481/454 SAE #s--some bolt-ons...
* '90 ZR-1 SGC built 368ci 'Factory Black Motor' (11.0 @ 130.2 & 11.2 @ 132.4) w/ the 368 (421ci Stroker coming!)--sprayed 120 shot.. 448 RWHP on motor, 560+ RWHP on the spray (SAE #'s)
Old 03-02-2008, 07:32 PM   #4 (permalink)
Depending on the build date of your Z...this re-call exists!
Take your vin number to your Stealer and ask about TSB PIP 4318A
Difficulty Shifting and or Low Clutch Pedal"
Old 03-03-2008, 06:06 AM   #5 (permalink)
dwjZ06's Avatar
Welcome Back Rick! Glad to see you posting again bro! Don
SIG by GR8 WHITE
Old 03-04-2008, 03:19 PM   #6 (permalink)
If your dealer checks out that TSB and determines the trans is OK, about the only other thing you an do is change trans fluids. Some people have had better luck with Amsoil ATF or Redline D4 ATF (yes our trans takes ATF). I put in the Amsoil ATF and noticed that once it had a chance to properly circulate (about 1 days driving) the shifting became smoother all around. Cold is still tighter feeling than when warm, but not quite as bad. Warm is almost like butter now. YMMV...
4wheels is offline   Reply With Quote
Old 03-04-2008, 10:22 PM   #7 (permalink)
Don't have a C6 Z06, so can't really comment on your problem, but if you decide to try the AMSOIL ATF option mentioned above, ordering info in my sig will point you in the right direction. PM if you have any questions.
Old 03-05-2008, 11:15 PM   #8 (permalink)
I have a question about these TSB's. Do they fix know problems at the factory?
lthrneck is offline   Reply With Quote
Old 03-06-2008, 06:23 AM   #9 (permalink)
Take it back to the dealership and let them fix it.
Z06vette.com,NCRS/NCM
2006 2LZ LeMans Blue Z06.
65 GTO,69 Z/28,70 1/2 Z/28,
Old 03-06-2008, 07:10 AM   #10 (permalink)
jrhunkler's Avatar
The dealer said there is nothing wrong... that I was shifting too hard and fast? bs if you ask me.
Old 03-06-2008, 07:55 AM   #11 (permalink)
Take the dealership service dept. personnel for a ride. You driving.
Old 03-06-2008, 08:46 AM   #12 (permalink)
I've had the same problem in my 08Z. It all happened while attempting to speed shift at the dragstrip while racing my brothers solstice GXP with a 75 shot of NOS. LOL. I know. I didn't need to speedshift, but what can I say. It was fun. I took the car to the dealership and they said the synchros were damaged as well as 2nd gear. They replaced the transmission under warranty. While I was experiencing the issue I was able to shift from 1st to second without grinding as long as the engine was under 2500rpms.
abarus is offline   Reply With Quote
Old 03-06-2008, 10:02 PM   #13 (permalink)
Not what I was asking, I mean if a problem is found do they correct the problem at the factory or keep letting the dealer fix them?
Old 03-07-2008, 12:06 PM   #14 (permalink)
In any production environment, that depends on a lot of factors... how severe the failure, how high the failure %, the fix required, where they are in the production cycle, if parts need to be reworked/modified/sent back to vendor, etc. I doubt you're going to find anyone to tell you from any big co like GM which problems are reworked in production & which ones are just left for the dealer to fix. It usually boils down to cost with any of them.
Old 03-07-2008, 09:46 PM   #15 (permalink)
If the guy says it's not a problem, it's bs. He's just trying to get rid of you. Take him for a ride.. you driving. Good luck.
Announcing: 2008 National Corvette Challenge May 9-10, 2008 REDGAR Quarter Mile 8 04-12-2008 08:33 PM
Need TSB for the shift fork problem. Please HELP! jrummi C5 Z06 - Pit Road 2 06-21-2005 11:26 AM
Skip Shift Bypass Install Problem Winchester C5 Z06 - Pit Road 6 04-16-2004 06:58 PM
Momo Shift Knob Problem Solved Jacob C5 Z06 - Pit Road 0 07-24-2002 07:10 PM
Shifter Jams on a hard 2 - 3 shift---Is it me or a problem GNX Guy C5 Z06 - Grandstand 35 12-02-2001 09:12 AM
