I'm looking to install a nicely built LS2 into my 07 Z06. The issue is the LS2 has a 24x reluctor wheel and my PCM is obviously looking for a 58x wheel signal. I was planning on using the LINGENFELTER converter box but it now sounds like they are on hold pending more testing!
Sooooo, I don't really want to pull the crank to get a 58x wheel pressed in so I'm wondering if anyone has had any luck at getting the the PCM programming to make the change there? I'm assuming this may not be possible or Lingenfelter wouldn't have made the module.
I'm still curious to see if anyone has found a way to get into that programming area or has found another way around this issue.
Thanks,
-John
