Old 01-05-2005, 07:32 AM   #1 (permalink)
3 inches wider then other covette models?
The new Z specs tout the car is "3 inches (76.2 mm) wider than other covette models. Does this statement (In your opinion) include the new C6? I love the the width of the Viper and if the Vette flattened out a bit that would be a super hulking look as well. What do you think?
RTY2005 is offline   Reply With Quote
Old 01-05-2005, 07:53 AM   #2 (permalink)
I believe they mean the C6 Z06 is 3" wider, at the fender flares, than the C6 coupe is at the same points.
Old 01-05-2005, 07:58 AM   #3 (permalink)
gotcha!! Thanks!
Old 01-05-2005, 10:31 AM   #4 (permalink)
1.5 inchs of "extra" fender on each side equals 3"
2002 Z-06 M/Y
2006 Tahoe LTZ White
2002 Dodge Viper RT/10 Red
1998 Dodge Viper RT/10 Silver
fyrcaptain is offline   Reply With Quote
Old 01-05-2005, 01:47 PM   #5 (permalink)
That will effect the top speed. In early ZR1 testing ( it was also 3" wider) They found that the LT5 (ZR1 engine) in a narrow body (regular coupe) to be 5 to 7 MPH faster due to increased drag.
Old 01-05-2005, 02:04 PM   #6 (permalink)
Send a message via AIM to Zoomin
Not only the wider body, but wider tires too, so more drag than the coupe.
"'tis better to have zoomed and failed, than never to have zoomed at all." - Zoomin, 2001
Zoomin is offline   Reply With Quote
Old 01-06-2005, 08:41 AM   #7 (permalink)
rwd
It should mean three inches wider than the base car's maximum width wherever that occurs. It's probably at the front flares, but it might be at rear brake scoops.
It cracks me up that after all the hype about aero and the horrible frc roof line that they ended up with a coupe that has a c/d of .31 (which is almost certainly .31X rounded down). That's IDENTICAL to the horrible old C5 Z06 notchback that Hill was criticizing.
And the C6 Z will have a greater frontal area than the C5 Z, so it'll have greater total drag.
rwd is offline   Reply With Quote
Old 01-06-2005, 08:48 AM   #8 (permalink)
Weighs nearly the same too.
Old 01-06-2005, 03:18 PM   #9 (permalink)
rwd
Quite correct. Looks like the C5 Z06 will be a bit lighter.
If they had thrown the aluminum frame, magnesium, carbon fiber and other tricks (passenger side manual seat!) at a C5 Z06 and left the wet sump alone, they'd have been way down in the 2900-pound range with a more slippery car, and for a lot less bucks.
I'm underwhelmed.
covette accident pic DomsZ06 The Garage 5 05-19-2006 07:43 AM
How many inches should the ZO6 be lowered? ZO6inmyfuture C6 Z06 - Pit Road 3 09-22-2005 11:36 AM
Covette C6 v8mbp C6 Z06 - Grandstand 7 11-09-2004 08:38 AM
22 inches of snow, 15 degrees zzerosix The Garage 47 02-17-2003 10:05 PM
Nine Inches Of Rain! Kazamar The Garage 4 07-08-2002 09:50 AM
