Old 03-12-2006, 05:38 PM   #1 (permalink)
Any Issues?
I have a rattle in the exhaust and a squeak on the right that sounds like a break wear indicator. The dealer has a new exhaust on order, but they have to come from the plant (none in stock). I have not taken it in for the squeak yet but will this weekend.
Every time the car is warm and I'm sitting at a light, it sounds like the exhaust is going to fall out it rattles so much. Very embarrassing. Then I take off, and the breaks squeak. Sure sucks when people look at you and point. It’s really bad now that the weather has turned and people have their windows open…
Oh well, it should be fixed soon… I'm done venting.
Ralf Racing, Inc. www.ralfracing.com
Fighting for the Cure - Leukemia and Lymphoma Society Partner
Car #25 Spec Miata SCCA - Racing in the Mid Atlantic Road Race Serries (MARRS) 2008
2006 Z06 Corvette for more fun...
Blitz is offline   Reply With Quote
Old 03-12-2006, 05:53 PM   #2 (permalink)
No thing like that with mine. Exhaust just roarssssssss
Tony
TZ06
Tony Skarbic is offline   Reply With Quote
Old 03-12-2006, 06:03 PM   #3 (permalink)
Blitz,haven't had any issues here.Your exhaust issue sounds like a bad catalytic converter-is that what they told you?
Bill
2006 Z06 Velocity Yellow
2006 Dodge Viper SRT-10 Coupe FE Blue/White
Vette & Viper-The AMERICAN "Killer V'S"
Orangesnake is offline   Reply With Quote
Old 03-12-2006, 06:03 PM   #4 (permalink)
briann510's Avatar
My Z has literally been driven into the ground for the last 24K. No real issues with anything so far.
2003 Z06 with A&A Vortech V-2 T-Trim package at 8 psi
briann510 is offline   Reply With Quote
Old 03-12-2006, 06:16 PM   #5 (permalink)
No issues here either!
06 Z06 VY, 2LZ, Polished, Nav
JBP8653 is offline   Reply With Quote
Old 03-12-2006, 06:25 PM   #6 (permalink)
Nothing but fun to get over. Oh, I only have 72 miles on it...Guess I better get busy....
constren is offline   Reply With Quote
Old 03-12-2006, 06:32 PM   #7 (permalink)
No, they said it was the muffler.
Old 03-12-2006, 06:32 PM   #8 (permalink)
Just some minor ones.....clutch shudders occasionally, interior rattles somewhere around or in dashboard and in rear under the mat. I took it in last week for 1,000 mile oil change and they said there was a leak in the differential. Will take it in this week for repair. Other than that, it's good to go.....fast.
2006 Z06 MS/BLK - Polished Rims - 1LZ
Tailbiter is offline   Reply With Quote
Old 03-12-2006, 07:01 PM   #9 (permalink)
Yeah, mines fast okay. The engine runs very strong. Just those minor problems. They'll get fixed.
Old 03-14-2006, 12:04 PM   #10 (permalink)
allanlaw's Avatar
You might want to wait and see on this repair. Sometimes the diff leak just goes away by itself after a few more miles.
Old 03-14-2006, 11:15 PM   #11 (permalink)
Thanks for the advise allanlaw. I'll wait it out.
Old 03-16-2006, 07:17 PM   #12 (permalink)
Well, I pulled all the tires off today and cleand and inspected everything. I noticed a rock in the right rear and that is what caused the noise. Thank God. My dealer called and the muffler parts are in. The car goes in next week for a new mufler...
Soon she will be perfect!
Old 03-16-2006, 07:56 PM   #13 (permalink)
johniew398's Avatar
Send a message via AIM to johniew398
3100 miles & 4 months for mine. Nothing so far.
2006 C6 Z06
2008 Viper ACR
2006 GMC Canyon
2001 BMW540i
johniew398 is offline   Reply With Quote
Old 03-23-2006, 05:18 PM   #14 (permalink)
markbrown's Avatar
clutch shudders
.....clutch shudders occasionally.
mine shudders also but only when i am going in first gear and have to like make a slow turn where i press in the clutch as i'm turning and re engage it. then the second time i engage it it shudders. i have the marbles in a can 1st and 2nd also, after that they go away. someone says its the shift knob but i doubt that.
markbrown is offline   Reply With Quote
Old 03-23-2006, 07:06 PM   #15 (permalink)
The "can of marbles" - though annoying - has nothing to do with the shifter - it actually has to do with vibration inside the gearbox itself. It's a well known phenomenon - particularly with larger gearboxes - and is called gear rattle. It is nothing to worry about, just a characteristic noise. I have not heard a Tremec box without it.
One way to eliminate it is to tune it out with a dual-mass flywheel, which actually allows torsional damping by "sandwiching" a rubber element between an initial flywheel at the crankshaft, and a second one interfacing with the clutch. This generally slightly reduces acceleration times from a stop because of a lag effect and additional flywheel total mass. GM decided performance was more important in a Corvette, and I agree.
BTW - I have also noted a slight engagement shudder - could be caused by Lt's of things including engine mount tuning. I've slightly modified the way I engage the clutch & it's OK now.
Luckily no other issues with the car yet - but only just gettin'er broken in since Spring has arrived.......
2006 Z06 2LZ LMB/Ebn
Prior 'Vettes: 99 Coupe MR/Oak/Z51/MN6, 02 Z06 EB/Blk, 04 Coupe MR/Oak/MM6
Misc. Projects: 61 Jaguar E-Type, 65 Pontaic GTO Sports Coupe
JCEng is offline   Reply With Quote
Steering issues spdrcrj C5 Z06 - Pit Road 4 06-08-2005 10:08 AM
This Woman Has Issues!! TexasBlue72 The Garage 6 05-25-2005 01:00 PM
Site Issues, Problems, Improvements and Suggestions. Post your issues here. FiveOJoe Site Questions or Suggestions 25 04-14-2004 06:10 PM
Issues with Halltech exSSer C5 Z06 - Pit Road 5 04-08-2004 06:59 PM
HELP....cars having issues my01z06 C5 Z06 - Pit Road 7 07-02-2003 12:54 AM
