Old 12-14-2005, 12:28 PM   #1 (permalink)
Backpressure issues
OK, back to the fuse again... can having it pulled (or switched off) for extended periods of time play havoc on backpressure at idle and low rpm's (and highway cruising)?
Are there any forseen negative side effects of having it pulled?
bjaber is offline   Reply With Quote
Old 12-14-2005, 01:06 PM   #2 (permalink)
It's like anything else. Your engine is mapped for a stock configuration, air flow, back pressure etc. So when you change one of those parameters the PCM compensates by adding or subtracting fuel while in closed loop. This is all well and good until you go to WOT or open loop. Now you will have slightly more fuel added to what's already commanded by the PCM. It's not really a big deal but not optimum either. The worse case is you run slightly rich.
Once tuning software comes out for the LS7, you can get it tuned and all will be right with the world once again.
Sig by the Hillbilly!
Old 12-14-2005, 02:42 PM   #3 (permalink)
Thanks, Jub. That's what I thought ...and it is running rich... got way less mpg on the last tankful. I've put the fuse back in for now. Ordered a switch unit from LG and will mount it. I just LOVE the way it sounds when the valves are open. They should have made it sound like that right from the get go. Awesome!
Any Issues? Blitz C6 Z06 - Pit Road 16 04-01-2006 09:36 PM
Backpressure on FI air1kdf C5 Z06 - Forced Induction & Nitrous 1 07-17-2005 12:23 AM
Need help with timing issues... MyblueC5 C5 Z06 - Forced Induction & Nitrous 13 01-12-2005 06:37 AM
Site Issues, Problems, Improvements and Suggestions. Post your issues here. FiveOJoe Site Questions or Suggestions 25 04-14-2004 06:10 PM
Backpressure.. the truth Royalshowing The Garage 8 01-12-2004 10:37 PM
