Old 12-11-2007, 09:54 PM   #1 (permalink)
Cloaked's Avatar
brake fluid question
Hey guys quick question, if you are running a little low on brake fluid and you're running the ATE blue can you top it off with a Synthetic DOT 4 without an issue?
Thanks
Marc
Cloaked is offline   Reply With Quote
Old 12-11-2007, 10:34 PM   #2 (permalink)
Re: brake fluid question
Yes, no problem.
However, if the brake fluid has dropped for some unknown reason, make sure you don't have a leak or that your brake pads are not excessively worn. Each of those will result in the fluid level dropping.
Old 12-11-2007, 11:04 PM   #3 (permalink)
Cloaked's Avatar
Thanks
Marc
brake fluid change question Ness70 C5 Z06 - Pit Road 15 05-04-2006 05:43 PM
Brake fluid question... JUICE C5 Z06 - Pit Road 2 03-29-2006 03:43 PM
Old Topic, but New Question-Brake Fluid ROSSO Z C5 Z06 - Pit Road 1 04-30-2004 03:06 PM
Brake Fluid Question slvr02 C5 Z06 - Pit Road 19 07-17-2002 07:41 AM
Brake Fluid Question... Stogo C5 Z06 - Pit Road 10 04-18-2002 03:56 PM
