Whosur, I have had the problem. I change back and forth from track and street pads and the bolts are very sensitive to stripping. GM only sells the bolts with the pads so I have had to purchase an extra set off pads just to get the bolts. I am planning to ditch the GM
brakes and go with stoptechs. DJ's advice is also good. I have been using anti seize and a dab of lock tite then torque to only 27lbs method with sucess for the past 4 events and only had to drill and EZ out one bolt since. 1st time through the brake system, 6 bolts of the 30 need to be drilled and EZed
Rick Moore
LG Long Tubes, Halltech fiter & tune, StopTech 6 piston, Coil Overs, CCW Wheels, Hoosier R6's, BPP shifter, Cavvaiggo race seats, Shark Bar, Impact Harness set, 482rwhp
