Old 01-06-2005, 09:22 PM   #1 (permalink)
C6 Z06 hits zero to 62.1 mph all in first gear in under 4 seconds!
"Impresive as the engine is, good aftermarket tuners are probably capable of squeezxing 500 hp into your Corvette. Where the factory has an edge is in engineering and constructing a complete design to take full advantage of the power boost, and Hills team has left very little on the table. Start with the electronics of course, fully intergrating the ABS , traction control and stability control systems, allamended to suit the new hardware." Autoweek
Old 01-06-2005, 09:25 PM   #2 (permalink)
Its definitely going to be hard for tuners to squeeze any more ponies out of her unless they supercharge
Hurst shifter, Ap racing brake set up 6 Piston Front 4 Piston Rear Vararam intake ,Preditor tuning,160 Thermostate,Throttle bypass tube,FLP headers,x-pipe and per cats,heatsheild
ls1jp is offline   Reply With Quote
Old 01-06-2005, 09:25 PM   #3 (permalink)
Manually controlled seats over pwer operated seats, larger side bolsters and z06 logo embroidery.
20 millimeter smaller steering wheel.
Hill says occasional weekend use of your Z06 won't void the warranty, unlike the case with some other manufacturers.
Base Z06 pricing will be in the mid 60's and with optioned versions running into the 70's. (autoweek)
Old 01-06-2005, 09:28 PM   #4 (permalink)
Yep,
I read that too
Can't wait to see some #'s on the gearing. I've seen 0-60 figures as low as 3.5 sec
Sounds like it may have a 3.15 rear axel?! Or, a lower 1'st gear in the tranny.....
Love the look Lotsa great pix in that Auto Week article
01ZEE06 is offline   Reply With Quote
Old 01-06-2005, 09:31 PM   #5 (permalink)
Although the stock car sounds awesome enough I tend to think tuners will manage to tweak the motor for even more performance once they figure out how to get into the pcm for tuning capability...throw in a wilder cam....maybe a set of long tube headers....(not sure if its worth the extra 10% more horsepower to void the warranty)
500's a pretty hefty number especially since it comes in fully warrantied...
Track events too according to Hills comments in Autoweek this week...
Old 01-06-2005, 09:38 PM   #6 (permalink)
Originally Posted by 01ZEE06
Yep,
I read that too
I was impressed with autoweeks coverage...
Best out of all the magazines I've read to date..
Not having to shift out of first to run to 60mph is quite a good idea for impressive Magazine numbers....
I was surprised by the fact that hitting such good performance numbers will be so easily repeatable as long as the driver gets a good launch out of the hole.
I have a feeling the active handling will aid the driver in getting consistant performance in a similiar fashion to the Ferrari F430...(different technology in the two cars)
Those huge tires....lower rear axle ratio? new technology and dam impressive performance..........
and with a warranty to boot.
Priced in mid 60's too according to the article as well...
Mid 60's! Fully optioned up around 70 sounds about right..
Old 01-06-2005, 09:40 PM   #7 (permalink)
PerforminNorman's Avatar
OH this kind of talk is just killing me.
Come to the Z06 Fest!
Performin' Norman
Old 01-06-2005, 09:50 PM   #8 (permalink)
RC45's Avatar
This is just Page Ranking speak - and will have to wait for the first broken cars to start needing repairs.
Old 01-06-2005, 09:53 PM   #9 (permalink)
FWIW! I would n't worry about it...
The C6 Z06 is going to be the worlds best!
Although I'm tired of seeing the Z06 C6 in yellow when the photos hit in silver or black....or red....I think it will be even harder to resist..
(yellows great..just tired of seeing the same color over and over again..)
Old 01-06-2005, 10:02 PM   #10 (permalink)
Torched's Avatar
I just read on another forum from Jim Hall that with 11:1 compression it will be difficult to put a supercharger or a twin turbo set up on. It seems GM has done this car right in raw cubes with little room for improvement. Greg
02 Z06 Torch Red/ Ebony AAB,DD0,B84,V49
Built 9-24-01, Number 7,896 02 Vette Off The Trim Line, 08 Z06 Jetstream Blue Metallic/Ebony
100% Satisfied Rick Daniel Customer! *NCM Individual Member #9781
Torched is offline   Reply With Quote
Old 01-06-2005, 10:54 PM   #11 (permalink)
Oh yeah with 11.0 compression ratio you guys should forget about going forced induction without reducing compression ratio.
Old 01-06-2005, 11:00 PM   #12 (permalink)
Send a message via AIM to wallyman424
im relatively confident that there will be alot of room for improvement in this powerplant. simply because this 427 puts out 500 flywheel hp, and we have tuners putting out 427's with around 620 flywheel hp (550-560rwhp). i think a cam on the new z will be a great deal for those who want to modify.
2001 #17 Z06 currently racing in NASA ST2
2003 TR Z06 -- sold *tear....
wallyman424 is offline   Reply With Quote
Old 01-07-2005, 02:44 AM   #13 (permalink)
Your right, Doug Rippie's 427 that came in second in "One Lap of America" was putting out 640 BHP, and I recently saw a tuner who had one at 650BHP. So, 500 BHP is pretty conservative.
By the way, the LS7 is really a 428 c.i. engine
Old 01-07-2005, 05:05 AM   #14 (permalink)
I wonder if the transmission is going to be differnet or not. If the transmission is different this new car will be a real big jump from this car. Everything is going to be new and not just improved.
Old 01-07-2005, 06:38 AM   #15 (permalink)
Send a message via MSN to itchynackers
We are not using mathematical averages here. The cubes are slightly over 427 (something like 427.6). This doesn't equate to a 428. You don't have a 428 ci engine, you do have 427 and change. If I've got $600,000, i'm not a millionaire.
Also, Dave Hill says "occasional weekend use will not void the warranty". I'm pretty sure every corvette owner drives their car on the weekends. Are our warranties voided? Does he mean occaisional weekend tracking? Is he setting us up for voided warranties?
Scenario: I go to dealership for a warranty issue.
Dealer: "Do you track the car."
Me: "Ya, I did my first event yesterday, but got this problem on the first lap."
Dealer: "Sorry, no can do."
Me: "But Dave Hill said...."
Dealer: "He said occasional weekend use, not tracking. You drive it every weekend, so.."
Me (bending over): "Thank you sir, may I have another"
Is GM playing games with semantics here?
itchynackers is offline   Reply With Quote
Video: 0 to 6000+mph in 6 seconds jeffareid The Garage 2 05-11-2006 08:51 PM
Newbie Question- Z06 gear ratios and mph cnair C5 Z06 - Grandstand 4 09-17-2005 09:37 PM
0-180 MPH in 14 seconds ZO6 DUST The Garage 15 08-26-2003 08:32 PM
0 to60 mph in less then 4.2 seconds! to 100 in less 10 Whoa! JBsZ06 The Garage 22 08-26-2003 01:31 PM
0-60 mph in 2.4 seconds!!!!!!! ZEEE 06 C5 Z06 - Grandstand 6 05-10-2001 12:08 PM
