Old 11-03-2005, 08:03 AM   #1 (permalink)
DJWorm's Avatar
C6 Z06 LS7 Dry Sump Info Needed
OK, I know the general layout of the system and I have seen the pre release photos of parts and internal and exploded views of the pan, pumps, reservoir tank, etc.
We all know that the TOTAL System capacity is 8 qts.
But I still have some questions and need more info:
1. Have we seen any schematics of the TOTAL system ?
A copy would be nice.
2. What are the external demensions of the reservoir tank ?
Height and Diameter ??
3. What is the capacity of the reservoir tank ?
(NOT the total system capacity of 8 qts.)
4. Who makes the reservoir tank?
- Is it outsourced ?? OR
- Made by Chevy ?? OR
- one of the Divisions such as Delphi/Harrison ?
5. Where is the engine oil cooler located ? Pictures?
- Is it a stand alone ? OR
- Is it integrated with the radiator ?
- Is it air/oil OR water/oil ?
- Where is it located in the system ? Again, Schematics ?
6. What output do the pumps have ?
- Pressure ?
- Flow ?
- Are they balanced ? (I'm sure they are.) And if so,
- How are they balanced ?
- To what are they balanced, flow or pressure or both ?
For tracking the car I propose the following possible upgrades:
- Increasing the Reservoir tank Size 1-2 qts..
- If aftermarket MUST also incorporate PCV lines
- Increasing the Oil Pumps Flow outputs by porting and polishing
- Increasing the Pumps Pressure outputs by shimming
- Balancing Pump Flow outputs
- Remote Oil Filter to Larger and possibly Multiple unit(s).
- Possibly installing an Accusump into the pressure side of the system.
These mods would increase Total Oil System capacity to 10-12 qts. and result in better cooling, better oiling, better filtration, increased safety.
AMSOIL Online Store
Old 11-03-2005, 06:28 PM   #2 (permalink)
Send a message via AIM to 99blackFRC
TTT.. Excellent questions
1999 Black Hardtop - 18/19 HRE 545 R series, Corbeau CR1 seats, RK hood, Patriot LS6 stage II 59cc heads, Crane doubles, Ti retainers, Harland Sharp roller rockers, TSP 231/237 cam, Manley push rods, Rollmaster timing chain, Comp 850 lifters, TSP ported oil pump,
99blackFRC is offline   Reply With Quote
What is a Dry Sump system?? Bob C5 Z06 - Pit Road 26 05-13-2008 07:48 PM
Wet vs. Dry Sump HeadHunter C5 Z06 - Grandstand 3 08-13-2006 07:21 AM
Dry Sump reservoir ?? DJWorm C6 Z06 - Pit Road 3 11-02-2005 02:52 PM
Dry Sump Info MA ZO6 C6 Z06 - Pit Road 10 08-18-2005 10:42 AM
LS7 Dry Sump System revealed: DJWorm C6 Z06 - Pit Road 31 04-24-2005 04:44 PM
