Old 07-20-2008, 02:06 PM   #1 (permalink)
C6Z06 competitive oil level
I see much about the C5Z, but what about the C6Z? I thought I read somewhere that the best oil level for competitive driving in the C6Z is less than 1/2 up the dipstick at most, but now I can't find that reference anywhere.
Please any thoughts? Going to BIR TOMORROW!!!
Old 07-20-2008, 10:56 PM   #2 (permalink)
PerforminNorman's Avatar
Re: C6Z06 competitive oil level
There is no need to change the oil level when you road race a C6Z. They are equipped with a dry sump system instead of a wet. This eliminates the need for overfilling when road racing.
Come to the Z06 Fest!
Performin' Norman
Old 07-21-2008, 03:30 PM   #3 (permalink)
allanlaw's Avatar
If you go much above the half-way mark (measured per owners manual) and you track the car, you may get the oil backing up into the air bridge from the breather tube, trickle down into the air filter and puddle under the driver side of the radiator. In the process of doing this, it may loosen the lower hydrocarbon pad in the air bridge, which can cause fluttering at high rpm or, if it comes totally loose, it can take out your throttle body.
Old 07-22-2008, 06:18 AM   #4 (permalink)
Thanks guys. That is what I was looking for. I actually already tracked it with oil almost at the top of the dip stick, after the day it was at 1/2 way up (250 miles!)..I'll check for oil out of the engine, etc, but the car just plain ran great (until I almost ran out of gas, but that would be my fault )
"Competitive driving" oil level? GS1000FF HPDE 15 10-09-2006 12:35 PM
Competitive Mode Metraman C6 Z06 - Pit Road 10 10-08-2005 05:30 PM
C6 TC/AH/Competitive Mode PerforminNorman C6 Z06 - Grandstand 4 09-01-2004 08:01 PM
Low Oil Level Message, Oil Level Looks Fine carsnguitars C5 Z06 - Pit Road 2 06-01-2004 06:58 AM
Competitive Mode Nice Rumble C5 Z06 - Pit Road 15 07-31-2003 03:58 PM
