Old 06-11-2006, 04:28 PM   #1 (permalink)
CAGS question
I know what CAGS does, but does it physically prevent you from shifting to any other gear other than 4th? Today I got the 1-4 light and I thought I was going to 4th but ended up in second by mistake and nothing seemed abnormal.
Also for the override, can you see the override when its installed or is it completely unnoticeable?
navyasw02 is offline   Reply With Quote
Old 06-11-2006, 04:42 PM   #2 (permalink)
FredLewandowski's Avatar
If you have a "CAGS Eliminator" installed you can shift into second and you are not forced into fourth! The display will still show the 1st to fourth message!
I installed the eliminator as soon as I got the car home from the dealer (30 mile ride on I-95) so I have very little experience using the tranny before "CAGS Elimination"!
Do you know if the car has a "Cags eliminator installed"?
"RED Z06", Torch Red '02,"C5 Z06" Machine Silver '04, Hardbar Harness Bars, 6 Point racing harnesses, C6 Z06 Shifter & Knob,'71 T-Top 454 LS7, '86 L98, '91 L98 Convertible, C5R OZ 13" wide wheel
FredLewandowski is offline   Reply With Quote
Old 06-11-2006, 04:46 PM   #3 (permalink)
It does not have one right now. I'm thinking of buying one. It just seems weird that I shifted into 2nd by accident with the 1-4 on. Maybe I just shifted really slow and let my speed go higher than 19 or whatever the cutoff is.
Old 06-11-2006, 05:46 PM   #4 (permalink)
RocketSled's Avatar
You probably hit the cut-off just as you were shifting gears, so it appeared as if the light was on, but the CAGS was *just* switching off.
C6!
Old 06-11-2006, 06:13 PM   #5 (permalink)
MSiska's Avatar
Yeah...this happens to me also.
And if I hit the 1-4 rpm range, and it's activated, I shift it into 4th and then back into 2nd.
Old 06-11-2006, 08:40 PM   #6 (permalink)
The engine coolant temperature has to be higher than 169°for Computer Aided Gear Selection to operate.
Old 06-11-2006, 09:19 PM   #7 (permalink)
No CAGS..I just wind first out until 2800 or so and then shift to 3rd ... I find it easier to go from 1, 3, 5 in traffic. I wouldn't recommend that for street or track though.
Otherwise, no it will not hurt your car, unless you lug the engine ....
"Temperance, like chastity is it's own punishment"
YellowGrin is offline   Reply With Quote
CAGS Defeat Question Joe Bruntz C5 Z06 - Pit Road 2 05-05-2005 09:49 AM
!CAGS Question Vrrooom C5 Z06 - Pit Road 5 10-12-2004 03:48 PM
Just Installed CAGS Have Question Torched C5 Z06 - Pit Road 19 09-03-2003 02:09 PM
Quick CAGS Question ZeeOhSix C5 Z06 - Pit Road 5 06-20-2003 09:21 AM
CAGS defeat question NYCHASM C5 Z06 - Grandstand 27 02-27-2002 08:07 PM
