Old 07-13-2006, 09:07 AM   #1 (permalink)
WhosUrDaddy's Avatar
Cracking Rotors [Image inside]
This car has seen six track days - 3 at VIR Full; 2 at Summit Point. Four of these days followed the installation of Carbotech XP10's.
Over this period of time I've noticed three things of note:
1) The rotors cracked easier and more severely than I guessed.
2) The XP10's were disappointing compared to my experience with them on my C5 Z06. I found them grabby, difficult to modulate and even worse - they "smeared" pad material too thickly across the face of the rotor. This last element caused pedal vibration and I'm betting increased pad wear.
3) I am disapointed at the above two issues after just six track days. I know my Porsche compatriots have found a way to make braking systems work better for a longer period of time on the track. The General should know how to do this as well.
Below is an image regarding the above.
Has anyone come across better OE rotor/pad options and achieved better results? I'm only a part-time track guy who'd like to do about 10-days per year. So going to aftermarket braking systems is not an option in my mind.
LB/BLK '06 Z06
WhosUrDaddy is offline   Reply With Quote
Old 07-13-2006, 09:28 AM   #2 (permalink)
The cracks look pretty typical for a cross-drilled rotor, my GT3 rotors are doing the same thing. I would suggest going to a slotted rotor rather than cross-drilled to avoid the issue in the future.
Duke 1 is offline   Reply With Quote
Old 07-13-2006, 10:38 AM   #3 (permalink)
panzer's Avatar
Consider getting slotted and dimpled. They cut the dimplee to the maximum depth of the rated wear for the disk. When you wear them to the point the dimples disappear it is time to get new rotors. Dimples look almost as good at the holes but do not create the focus point for the cut points to crack from.
1985 BMW K100 m/c
Old 07-13-2006, 12:14 PM   #4 (permalink)
GR8 WHITE's Avatar
Hows this for a cracked rotor? 12 laps at Hockenheim!
http://smg.photobucket.com/albums/v3...nch =imgAnch1
GR8 WHITE is online now   Reply With Quote
Old 07-13-2006, 10:05 PM   #5 (permalink)
WhosUr,
I had the same issue... among others, with the stock setup. I have since put on a StopTech brake kit. To avoid future issues.
Rick Moore
LG Long Tubes, Halltech fiter & tune, StopTech 6 piston, Coil Overs, CCW Wheels, Hoosier R6's, BPP shifter, Cavvaiggo race seats, Shark Bar, Impact Harness set, 482rwhp
Velocity is offline   Reply With Quote
Old 07-14-2006, 03:36 AM   #6 (permalink)
- duct tape or superglue - that should do the trick!!
TAILWAG is offline   Reply With Quote
Old 07-14-2006, 07:09 AM   #7 (permalink)
That failure is typical of "drilled" rotors. I put "drilled" in quotes because in the C6Z the holes are actually cast in. Cracks like you show happen in Porsches all the time.
I have a matching set of cracked rotors from my track days at Pocono.
Regarding your complaints about the XP10 pads, use XP12s. They are a much better pad (higher temp) with more progressive friction and no excessive initial bite. You will like them better than the XP10s for just a few bucks more.
So far I have not found reasonably-priced undrilled rotors on the market. As soon as I find a supplier, I will be buying them. Gary Hoffman has a two piece floating rotor with aluminum hat that looks pretty good, but is about $375 per corner. The rotor portion itself (the part you replace) is over $200 per corner. A bit too salty for my taste.
Other manufacturers offer rotors (Brembo, Stoptech, etc.), but they are even pricier.
Don't forget that you are going cosiderably faster in your C6Z than your C5Z, so more brake heat is unavoidable.
What we need are good NAPA rotors for $25 each.
Frank Gonzalez
gonzalezfj is offline   Reply With Quote
Old 07-15-2006, 07:22 AM   #8 (permalink)
Porsche relies on the following assessment of brake disc wear: "brake discs have to be replaced (as a precaution) [if the] length of perforation hole cracks is more than 5 mm (this means that no service life reserves remain if brakes continue to be subjected to severe loads) and/or if cracks appear at the edge of the brake disc (reduction of braking comfort and of breaking strength)."
Doc V. is offline   Reply With Quote
Old 07-15-2006, 07:27 AM   #9 (permalink)
I agree
jjwvette is offline   Reply With Quote
Old 07-17-2006, 11:02 AM   #10 (permalink)
Vette Doctor
c4c5specialist's Avatar
HI there,
Per GM TSB, the following inspection procedure is for all J55 equipped Corvette.
The pass criteria for thermal fatigue testing specifies that the rotor is allowed to have small thermal cracking up to 2/3 of the brake plate surface. The brake plate surface for the front rotor is 50 mm (1.96 in) radially which means cracks are permitted up to 33 mm (1.29 in) radially across the rotor brake face in length. This would be the pass criteria for the end of severe testing. To have a large safety margin, a rule of thumb -- "small" thermal cracks are allowable and the rotor does not need to be replaced unless the cracks connect from hole to hole or the crack reaches the OD of the rotor.
Allthebest, c4c5
Old 07-17-2006, 12:10 PM   #11 (permalink)
blkZ06's Avatar
I run stock rotors
$18/each
last 4-6 track days with Carbotech XP 10 pads
Old 07-17-2006, 01:23 PM   #12 (permalink)
allanlaw's Avatar
Originally Posted by blkZ06
I run stock rotors
$18/each
And you get stock rotors for a C6Z06 for $18 each WHERE??
Old 07-17-2006, 08:18 PM   #13 (permalink)
blkZ06's Avatar
don't have a C6
see signature
Old 07-17-2006, 11:19 PM   #14 (permalink)
allanlaw's Avatar
don't have a C6
see signature
So the relevance of your post on the C6Z06 forum is ?? We are looking for alternatives to the stock swiss cheese rotors.
Old 07-18-2006, 12:54 AM   #15 (permalink)
blkZ06's Avatar
whoah! chill there
I didn't realize that was the only rotor choice for a C6, my mistake
geez!
Question about cracking a rotor. z06_23_45 C5 Z06 - Pit Road 9 10-10-2004 02:12 PM
Save your fenders from cracking underneath!!!! jub jub C5 Z06 - Pit Road 23 11-22-2003 06:01 PM
KD's cracking robiferretti C5 Z06 - Grandstand 11 09-08-2003 12:55 AM
Cracking Dash Bill Etiz C5 Z06 - Grandstand 8 06-25-2003 12:11 PM
Factory DEFECT? (A-pillar leather cracking) YOURS TOO?! KMeloney C5 Z06 - Grandstand 8 09-17-2001 06:51 AM
