disable auto headlights
This is how to disable the auto headlights and keep the DRL.
- remove the grill over the center speaker on the dash
- twist and remove the ambient light sensor from the grill cover
- disconnect the light sensor (tip, might have to use a needle nose to push to release it cause it's very tight)
- get some 2.2k 1/2 watt resistors
- put a resistor on the side with the yellow wires (you may have to trim the resistors so it doesn't stick out)
- put some electrical tape around the resistors
- for aesthetics, put the light sensor back on the grill cover
- put grill cover back on
- ya done!
