Old 05-15-2008, 11:57 AM   #1 (permalink)
Does changing tire size confuse traction control
The wheel rpms and the rpm ratio (front to rear) changes from the stock set-up: Has anyone experienced any unnecessary engagement of the traction control?
gandoff is offline   Reply With Quote
Old 05-15-2008, 03:13 PM   #2 (permalink)
Re: Does changing tire size confuse traction control
If the overall diameter of either the front or back wheel/tire varies by more than ~3% from stock then yes, it can and has been known to cause problems with traction control.
Old 05-16-2008, 05:58 AM   #3 (permalink)
6speeder's Avatar
Running 345/30-19 and 275/35-18 Nitto Invo's, or 345/35-18 and 295/35-18 Hoosier R6's, no issues. Active handling, ABS, and traction control work just like with stock sizes.
2007 Velocity Yellow Z06
543 rwhp/493 rwtq SAE
Old 05-16-2008, 08:49 AM   #4 (permalink)
JerryL's Avatar
Just keep the new sizes within 3% of the OE size you are replacing. You should have no issues.
JerryL is offline   Reply With Quote
Old 05-16-2008, 09:00 AM   #5 (permalink)
DennyM's Avatar
RocketSled has a handy-dandy calculator available thru his sig link.
Old 05-16-2008, 09:21 AM   #6 (permalink)
I'm running a set of drag radials for trips at the strip. No issues.
335/30/18"x12" and the nitto's.
Z06vette.com,NCRS/NCM
2006 2LZ LeMans Blue Z06.
65 GTO,69 Z/28,70 1/2 Z/28,
Old 05-16-2008, 05:14 PM   #7 (permalink)
RocketSled's Avatar
Click on the RocketSled, scroll to the bottom of the page that opens, click the link for the tire size spreadsheet. It's fairly self explanatory.
C6!
Old 05-20-2008, 09:34 AM   #8 (permalink)
allanlaw's Avatar
Running 18" wheels in the rear, I've noted that Nitto 555RII's will trip TC on occasion at speeds over 85mph; Nitto NT01's always at speeds over 50mph.
Old 05-20-2008, 10:20 AM   #9 (permalink)
DennyM's Avatar
What size tires front/rear on the RII's and what size NT01's ?(I assume 315/30 rear for the NT01's)
I'm running Nitto 555rII 275/40/17 in front and 305/35/18 rear and have had no issues ...
Old 05-20-2008, 10:42 AM   #10 (permalink)
allanlaw's Avatar
RII was 285/35/18 . . . 305/35/18, and TC tripped only a few times (hot air temp, over 85mph).
NT01 is 275/35/81 . . . 315/30/18, TC trips all the time at 50mph.
Old 05-20-2008, 12:04 PM   #11 (permalink)
DennyM's Avatar
OK, gotcha ... this Rocksled whiz-wheel says ...
Rear Front
295/35/18=26.13" | 265/40/17=25.35" |Delta: 0% (OEM)
305/35/18=26.41" | 285/35/18=25.85" |Delta from OEM baseline: 0.9% OK
315/30/18=25.44" | 275/35/18=25.58" |Delta: -3.6% might be too much delta (note the rears are slightly smaller than the front ...)
Old 05-20-2008, 02:30 PM   #12 (permalink)
RocketSled's Avatar
Yeah. But instead of the 315/275 combo, you could go with 315/30-18s on the back and 285/30-18s on the front, which is only a 0.2% variance. This is what I have been running for the last 3 years no problem.
Note also, the TC function is probably not "bi directional". It looks for the rear wheels to be turning faster than the fronts, but I kind of doubt it looks for the opposite. The TC system may in fact tolerate a larger variance from the OEM ratio if it's the rear tire that's getting bigger (since this makes the rear axle look like it's going slower for any given road speed) with respect to the front tire than the other way around...
Old 05-20-2008, 03:27 PM   #13 (permalink)
I believe these C6s (at least the Z06's, not sure about regular C6's) have an "engine drag" monitor in the TC system, where if it sees the rears turning too slow relative to the front, they think that excessive engine braking has locked the rears & increases throttle slightly. I can't remember where I read this, but I know I heard something regarding this.
4wheels is offline   Reply With Quote
Old 05-20-2008, 04:28 PM   #14 (permalink)
allanlaw's Avatar
I'm not sure what you're referring to, but there is no 285 available in NT01 so I'm stuck with what I've noted above. I really don't care about the TC having to stay off.
FS: Brand new RaceLogic traction control system with launch control jimlab Member Sales - Parts & Cars 14 12-31-2005 02:51 PM
Changing Tire Size....what happens to TCS and ABS? MADN3SS C5 Z06 - Pit Road 5 11-15-2005 10:57 AM
Traction Control rebells6 C5 Z06 - Pit Road 13 08-11-2005 11:48 AM
Traction Control Mike B C5 Z06 - Pit Road 6 11-02-2002 07:50 PM
Traction Control ? ZO6/Les C5 Z06 - Pit Road 19 11-16-2001 05:31 AM
