Old 12-15-2007, 02:10 PM   #1 (permalink)
I need better brakes for my C6 ZO6
Seems Brembo, Stop Tech, and Wilwood all have kits available. Anyone have experience with any of them? Thanks for your help.
speedmark is offline   Reply With Quote
Old 12-15-2007, 02:31 PM   #2 (permalink)
Re: I need better brakes for my C6 ZO6
Doesn't some company now make 1-piece race pads for the C6Z caliper? But, though I am no expert, you might consider something like that, a new set of SS lines and maybe some 2-piece rotors to eliminate some unsprung weight.
Old 12-17-2007, 12:30 PM   #3 (permalink)
Stop Tech: Very nice upgrade over stock and at a good price.
Brembo: Not just the name, but great brake kits.
I would stay away from Willwood. I've heard some bad things about them. I would also look into the one-piece brake pads for the C6 Z06.
Old 12-17-2007, 03:45 PM   #4 (permalink)
DennyM's Avatar
Welcome to
I can't remember what I read about C6Z pad options ... I know there are some ...
Here's some leads for you.
Tracking the Z and Brake issues....
Front BBKs
Brakes now seem to be fixed!
Enjoy your new addiction!
DennyM is online now   Reply With Quote
Old 12-17-2007, 05:26 PM   #5 (permalink)
I know a pad upgrade would help,but if you are looking for the best then I would go with Brembo. If I ever save enough money I know that is what I will get. MTI Racing has them on there own cars and they work great,of course they are $$$$$ 6500.00 installed last I checked.
Sky1 is offline   Reply With Quote
Old 12-17-2007, 07:10 PM   #6 (permalink)
allanlaw's Avatar
What is it that you want the "better" brakes to do? The stock brakes and pads are fine for street use - if you want less dust and you don't track the car, then Hawk ceramic pads would be a good bet. For moderate track (road track) use the stock setup is still good. Heavier track use and you run in to the stock pads not lasting very long, to the point with very heavy track use (especially on certain tracks) where you absolutely need track pads. While track pads are available for the stock calipers, the padlet design is just not equipped to handle a lot of heat so at that point a BBK may be called for. Be careful to make sure the selected BBK will fit behind your wheels. Either Stoptech or Brembo's are fine - there are folks that swear by either one (and hate the other). Personally, I do 12-20 track days per year, mostly at a track that is not too demanding on brakes. I'm running DBA 4000 slotted one-piece rotors up front, stock rotors in the back and Hawk HP+ pads. I also have an extension on my brake air duct to bring the flow to the edge of the rotor.
Old 12-18-2007, 06:54 PM   #7 (permalink)
OneSickZ06's Avatar
You need to press the pedal a little bit harder.
OneSickZ06 is offline   Reply With Quote
brakes vcav C5 Z06 - Pit Road 1 04-02-2004 12:20 PM
New brakes are in Eric C5 Z06 - Pit Road 8 04-02-2004 06:19 AM
Brakes MDZ06 The Garage 7 12-10-2002 06:07 PM
brakes rajn72 C5 Z06 - Pit Road 0 11-14-2002 12:54 PM
Sport Bike Brakes vs. Z06 Brakes Lou The Garage 12 06-17-2002 08:23 PM
