Old 07-21-2008, 05:49 PM   #1 (permalink)
Low to No Oil Pressure
While Running in the HPDE down at VIR my heads up display showed the imfamous "check gauges" while running about 140 down the frontstrech. Looked down and what did i see.. about 5lbs of oil pressure! Uh oh....
So after limping around the track and bunching up the field. i finally made it back to pit road. While at idle it had 0-2lbs of oil pressure.
So, long story short the car has been taken back to the dealership. Hooked up to a mechanical gauge, and has been determined that the bottem end has good oil pressure. But, the top does not. No spun main bearings. No cam bearing spun either. The motor is currently out of the car and in pieces. The dealership has been on the horn all day long with GM and they are puzzled aswell.
No engine modifications have been done. just intake, headers, tune. Thankfully this work is going to be coverd by warrenty. But from what we have heard. A new engine might be on its way.
anyone had any problem like this? Trying to get it fixed before Road America in August
P.S. if you were in the blue group first thing tuesday morning and saw a slow yellow z.... sorry! Half a lap eariler i passed a new zr1. felt great till this happend.
06 Velocity Yellow Z06. Fest V, VI.
Screamin Z is offline   Reply With Quote
Old 07-21-2008, 08:04 PM   #2 (permalink)
Re: Low to No Oil Pressure
Wow, I would want the whole new motor. I remember someone posting some other LS7 disasters. They suspected there were more than GM was letting out based on the amount he had heard of in his circle. I hope as we all start getting some REAL miles on this engine it is'nt a problem motor in regards to longevity. I raised this issue a while ago because I believe from what I see most guys are not putting big miles on the LS7, like alot of us did on the LS6. I'm guilty too, I'm only at about 10,000. When I asked a while ago the highest mileage LS7 then was I think 34000. I asked then because of the rocker issues and roller bearings. Please let us know what they determine. Good luck Jim
Old 07-22-2008, 02:03 PM   #3 (permalink)
allanlaw's Avatar
I hope so for your sake. Intake, headers and a tune could be considered engine modifications for warranty purposes, especially when looking at an engine replacement. If the GM zone rep comes around for a pre-replacement inspection and picks up on the tune, you may be out of luck. It's on their checklist.
Old 07-22-2008, 03:28 PM   #4 (permalink)
Well while at VIR we had a "High end" GM employee pretty much give us his card and said dont worry.. its coverd
Old 07-22-2008, 05:12 PM   #5 (permalink)
allanlaw's Avatar
I'm rooting for you - let us know how it turns out.
Old 07-22-2008, 06:24 PM   #6 (permalink)
I can't imagine what your current condition would be if you hadn't had the HUD! Especially at 140mph!
SAString is offline   Reply With Quote
Old 07-22-2008, 07:08 PM   #7 (permalink)
DennyM's Avatar
Welcome to ... from MI, yet ...
Old 07-23-2008, 11:56 AM   #8 (permalink)
Well just got news back from the dealership it was a spun main bearing.. They just now figured that out...... geesh. The crank is junk aswell.
Old 07-23-2008, 04:58 PM   #9 (permalink)
God Bless America
Old 07-23-2008, 06:46 PM   #10 (permalink)
Are you getting a new motor from GM?
Old 07-24-2008, 02:46 AM   #11 (permalink)
yup complete new motor + complete dry sump kit.
Old 07-24-2008, 05:15 AM   #12 (permalink)
I know in the Subaru world thin oil was being blamed for spun bearings...If you're over your grief, can you post some info on the oil type, wt, temp, etc? To help us prevent this on our cars?
Thanks and good luck..Hope to see you at RA!!
Old 07-24-2008, 10:15 PM   #13 (permalink)
CanadaGrant's Avatar
I'm pretty surprised that with headers and a tune they gave you warranty. You hit the "I'm lucky" button on this one...
CanadaGrant is offline   Reply With Quote
Old 07-25-2008, 08:04 AM   #14 (permalink)
If we didnt meet that GM employee then it most deffinatly would have been out of pocket.
Old 07-28-2008, 07:41 AM   #15 (permalink)
I had exactly the same experience in my '08 ZO6, also at VIR, during a Memorial Day DE. When the dealer folks did their initial inspection, they said they couldn't be sure without tearing it down, but major engine damage was possible. Well, no kidding, it was knocking, and no oil pressure, so I'm sure a main bearing was gone. I told them not to touch it, and that I wanted a new engine installed at the factory, which is what happened. The whole process took about a month. Seems there is now a dedicated team that does nothing but replace LS7 motors, guess that's both the good and bad news! The end result was totally acceptable, but something is going on with these motors.
elh0102 is offline   Reply With Quote
Oil pressure Billyg02 C5 Z06 - Pit Road 12 12-23-2006 07:08 PM
Oil Pressure nitro33498 C6 Z06 - Pit Road 10 10-25-2006 01:56 PM
Air Pressure Mikels6 C5 Z06 - Grandstand 8 07-25-2004 01:10 PM
Air Pressure ultra12 C5 Z06 - Pit Road 11 12-18-2003 06:12 AM
Oil Pressure loucas C5 Z06 - Grandstand 7 03-25-2002 07:39 AM
