Old 07-26-2005, 10:44 AM   #1 (permalink)
Deck-plate honing???
The C6 Z06 web site discusses "deck-plate honing of the cylinders". Whud 'dat? I'm an old Navy guy and am well familiar with deck-plates; something you are always chipping and painting. I'm sure that's not what they are referring to but what is it?
NVGRWUP is offline   Reply With Quote
Old 07-26-2005, 10:55 AM   #2 (permalink)
Send a message via AIM to Z06ified
I can't remember the exact details of deck plate honing, but I believe it is a process where they bolt a plate onto the top of the block where the heads go, and torque the head bolts down onto the plate to 'load' the block, before they hone the cylinders and top of the block. This ensures more accurate cylinder and block tolerances, as a block can distort slightly when under head bolt torque. They typically do this process when building race engines.
'02 Z06 , Electron Blue, Vortex intake, Magnaflow X-pipe, Corsa Indy, Stainless Works LT headers, LS1 Edit, TB bypass, Hurst, MGW Gripper, Born 2/20/02 380 rwhp / 363 rwtq
Z06ified is offline   Reply With Quote
Old 07-26-2005, 11:03 AM   #3 (permalink)
You are correct and IMHO should be used even when honing out lawn mower engines. It pre-stresses the block to promote a better ring seal. Some builder's will not only torque plate hone a block but will install the correct head gasket and run warm water through the block as well. Some even bolt up freeze plugs, block plugs, bell housing, water pump and pan.
D.J.
2007 Silver Z06
2000 Coupe
Old 07-26-2005, 11:07 AM   #4 (permalink)
A heavy metal plate that is bolted to an engine block during cylinder-honing operations. This helps keep the cylinders perfectly round.
Old 07-26-2005, 11:24 AM   #5 (permalink)
02 MY Z06 440RWHP/402RWTQ - Sold
08 BLK/BLK Z06 - Bone Stock
Old 07-26-2005, 11:40 AM   #6 (permalink)
What engines are not hand ass.? Robots,I dont think so.
bobby778 is offline   Reply With Quote
Old 07-26-2005, 11:45 AM   #7 (permalink)
Originally Posted by jub jub
What in the world is that? All you need is an anchor chain and you'll be all set Jub. Overall it does show the deck/torque plate and that's what we needed.
D.J.
Old 07-26-2005, 12:06 PM   #8 (permalink)
So true.
Every time I hear about something being hand built I hark back to the time when I had one of our local "hot shot" Trans builders build a transmission for my race car. My trans is upside down on a stand and the guy is dropping ash's from his cigarette into my valve body while he's talking to me. The valve body was full of fluid and the ash's dissolved upon contact with the fluid. When I asked him if cigarette ash's would harm anything in the valve body he said don't worry I'm real careful, see nothing's in there yet. Go figure.
D.J.
Old 07-26-2005, 06:19 PM   #9 (permalink)
There have been at least two magazines invited to view the brand new engine assembly plant. One was Chevy High Performance and from the pictures and descriptions, it was nothing like your local machine shop. Everything is like an operating room at a hospital. Each station requires checking in and out by bar codes on a computer before and after each process. Also assembled parts are painted with marker to signify completion. It was very impressive.
As an interesting related side point. At Bowling Green, they wear outfits like doctors in the paint rooms and those are not open to visitors in the factory tour. They take paint as seriously as we buyers.
constren is offline   Reply With Quote
Old 07-26-2005, 08:07 PM   #10 (permalink)
Send a message via AIM to jdogg
The difference here is that one person builds an engine, versus one person doing the same operation 8 hours a day.
jdogg is offline   Reply With Quote
Old 07-27-2005, 07:50 AM   #11 (permalink)
TX to all for the informative responses. I kinda figured that from the "plate" part of the term-it was the "deck" that had me adrift!
Old 07-27-2005, 08:19 AM   #12 (permalink)
To bad it turns out looking like an orange...the paint on vettes is horrible.
THRLSKR is offline   Reply With Quote
Old 07-27-2005, 08:50 AM   #13 (permalink)
DJWorm's Avatar
The key wording with the LS7 is:
"....hand built by one person only."
A single technician "walks" each engine thru the process from start to finish and "signs" his work. This eleminates a variability in the Q&A. You may have variability between Assemblers and engines but a problem can be more easily identified.
- Quality is much improved and proven to be. Mercedes, Porsche & Ferrari have proven this method on their high end models.
- A problem associated with 1 assembler can be quickly identified.
- A problem in engines assembled by many assemblers therefore is not an assembly problem but an engineering, part or process problem.
AMSOIL Online Store
This hand built engine thing is overblown. DavidNJ C6 Z06 - Pit Road 17 01-24-2005 10:11 AM
Autoweek: Hand-built Z06 engines rjsnyder C6 Z06 - Pit Road 12 12-16-2004 01:31 AM
Hand built engines at the new GM engine plant sodian C6 Z06 - Pit Road 3 08-29-2004 06:35 PM
LG Long tubes (hand built) complete system for sale 22655TD Member Sales - Parts & Cars 16 08-19-2004 05:07 AM
Anyone see THEIR Corvette Being built 1st hand GNX Guy C5 Z06 - Grandstand 4 03-17-2001 04:56 AM
