Old 07-20-2008, 05:36 PM   #1 (permalink)
Need HELP!!! Tire question
Hi All,
I have new Kuhmo front tires and am planning on putting new Continental tires on the rear. Both sets of tires are ZR rated. Will mixing tire brands cause any handling problems or wear problems? Thanks,
John
'73 Vette, L82, NOX, (Sold)
'81 Vette, (Sold)
'01 Z06 (Traded in)undefined
'02 Z06, Torch Red, Black, Completely Stock (Sold)
'06 C6, Black
John Youngblood is offline   Reply With Quote
Old 07-21-2008, 06:47 AM   #2 (permalink)
DennyM's Avatar
Re: Need HELP!!! Tire question
IMHO ...
Different brands are not a big factor, but tire construction and size differences can be ... you can expect handling differences if ...
Sizes and profiles F/R are a different ratio than tires you took off, e.g., fronts are OEM size and rears are 20mm over ...
Thread design and tread rating (UTGQ ... or "softness" ) are significantly different, e.g., fronts are 220 and rears are 320 ...
Wear is usually a function of use, alignment, and compound "softness"
BTW, John ... your question is really not model-specific, but you posted this in the C6Z section ... and your profile says you have a C5Z ...
If you in fact still have a C5Z I'll move your post to that section.
Old 07-21-2008, 10:14 AM   #3 (permalink)
RocketSled's Avatar
And lest we not forget, the TC and AH functions have built in assumptions about the different "stagger" in diameter between the front and rear tires. You cannot change sizes without doing a little homework, or risk a problem with the performance of these subsystems.
C6!
Tire Question DavePro C5 Z06 - Pit Road 2 03-04-2006 03:51 PM
Tire question Mr. C's 5 C5 Z06 - Pit Road 4 05-20-2005 06:18 AM
Tire question Greg Irvine C5 Z06 - Pit Road 6 11-11-2004 07:34 AM
Tire Question? Cat C5 Z06 - Grandstand 3 06-20-2003 03:50 PM
My tire blew and I just paid $400 for a new rear tire! Story and Question inside... don527 C5 Z06 - Grandstand 22 09-23-2002 10:34 PM
