Old 02-16-2006, 12:13 PM   #1 (permalink)
Proper Lifting Proceedure
Based on the other post relating to the improper Z06 lifting proceedure, I would like to inquire about the PROPER proceedure & pickup points for my C6-Z.
I have a Challenger 2 post lift with adjustable height rubber pickup pads
2006 Lemans Blue Z06
GlennSullivan is offline   Reply With Quote
Old 02-16-2006, 12:15 PM   #2 (permalink)
Remove the pads from your two post and get you some jacking pucks for the frame. Drive the car up on boards to get some height. You can then position the arms so they lift on the pucks. Same procedure I use for my C5 Z.
Sig by the Hillbilly!
Old 02-20-2006, 10:39 PM   #3 (permalink)
I heard the pucks are different for the 06 Z06 because the frame is thicker.
2006 Z06 LB/Ebony, Nav, 2LZ, QL9 and FE9 (No NE1).
Blu06Z06 is offline   Reply With Quote
Old 02-21-2006, 07:34 AM   #4 (permalink)
MSiska's Avatar
Nope...not true. I put mine up on a lift at our club's last shop night. Used the same pucks I made for my C5Z06.
Old 02-21-2006, 11:52 AM   #5 (permalink)
PerforminNorman's Avatar
Bingo. My Jacking pucks were made for the C5 and fit on the C6. Now, I have to find a reason to jack it up.
Come to the Z06 Fest!
Performin' Norman
Old 02-21-2006, 06:52 PM   #6 (permalink)
allanlaw's Avatar
You made them. The metal ones that are manufactured for the regular C6 will not lock into the C6Z06 transit slots because the frame metal is too thick to allow the puck to make that 1/4 turn once it's in the slot. Ask me how I know . . . My old C5 pucks use a magnet to hold them on, and the aluminum frame screws that up. Anyway, I'm back to using plain old hockey pucks again.
Old 02-21-2006, 10:57 PM   #7 (permalink)
Thanks! Thats what I was trying to say
Old 02-22-2006, 08:57 AM   #8 (permalink)
MSiska's Avatar
Ok...I see... The manufactured ones won't fit. Maybe I'm cheap, but Sports Authority sold me four pucks for $4.00. And they work pretty good. No probs.
Old 02-22-2006, 10:06 AM   #9 (permalink)
Mine are from elite engineering and they fit. Don't forget, the height of the pucks may not be the same. These ARE aftermarket parts.
Old 02-22-2006, 05:12 PM   #10 (permalink)
Thanks for the info, I did a quick Google Search and see lots of vendors selling "Vette lifing pucks" Does someone have a picture of the "pucks in use" to give me a visual?
Old 02-22-2006, 05:14 PM   #11 (permalink)
I agree
jjwvette is offline   Reply With Quote
Old 02-23-2006, 03:50 PM   #12 (permalink)
Norm,
I bought the C6 pucks from Elite Engineering. They work fine on my C5 convertible, but they do not turn in my C6 Z06. It definitely seems like the C6 Z06 frame is thicker to me.
Axel
02 Electron Blue/Black Z51 convertible
06 Black/Red 2LZ Nav Polished Z06 NCM
NCM Lifetime Member
Axel is offline   Reply With Quote
Old 02-24-2006, 01:26 PM   #13 (permalink)
Originally Posted by Axel
Norm,
Axel
i bought some lifting pucks for a bmw that are supposed to fit the c6, but they dont snap in, not because the whole frame is thicker, but there are certain welds of metal that intrude near where the puck goes... so i dremmeled down the plastic on the pucks on the part that contacted the bits of intruding frame, and they snapped in. so, i think it is thicker, but only in parts.
blackc6 is offline   Reply With Quote
Old 02-25-2006, 04:15 AM   #14 (permalink)
So could I make the assumption that if I went to an Authorized Chevrolet Dealer I could buy the Pucks GM makes and/or sells specifically for use when servicing the C6Z
Old 04-06-2006, 02:49 PM   #15 (permalink)
Norm,
Axel
Actually the C6 Z06 does require a little different size Jacking Pad. We have designed on that will work with the larger aluminum rails of the new Z06. Give us a call
www.eliteengineeringusa.com
Elite Engr is offline   Reply With Quote
Lifting Pucks GlennSullivan C6 Z06 - Pit Road 9 04-07-2006 10:31 AM
Lifting pucks, whose got em' Joslyn Vendor Sales - C5 7 03-09-2003 08:11 PM
Lifting a tire? What does it take? McRat Racing 9 01-18-2003 04:13 PM
Lifting car - is this ok? dimer0 C5 Z06 - Pit Road 10 07-02-2001 10:35 AM
Lifting the Z06 ELF Z06 C5 Z06 - Pit Road 1 03-19-2001 09:17 AM
