Old 02-07-2005, 08:42 PM   #1 (permalink)
The Pros and Cons of a 60mph First Gear
So let's start with some conjecture hear. Not about the 60mph, that is explicit in the literature. About the gearing and power curve.
For the power curve, I will rely on Car and Driver and the published specs. Those spec show 443hp at the torque peak, 500hp @6200, and C&D showed around 450hp at the 7000rpm redline.
For gear...a little conjecture. Transmission technologies lists only one T-56 with a high enough torque rating for the Z06. It has the same ratios as the Viper and the standard C6. So the assumption is that is the transmission. Of course, the C6Z may have custom gearing.
For the rear end, to hit 60 with a 2.66 first gear you would need a 3.15 rear. And it just so happens that this combo, with a 1.30 gear, would hit 127 in third. What a coincidence!
Now, the pros and the cons. The C6Z has a very flat power curve. for the top 30% of the rev range the power varies only about 12%. And it is the same at the redline as after the shift. Put in another way, you have the same acceleration in 2nd at the redline as you do in 3rd after the shift.
So, as long as you are in that range, it really doesn't help much to have additional gears. Once you hit the mid-4k range, assuming your tires are hooked up, nothing is really lost in the gearing. The question is, will you spin the tires until 40mph?
For road courses, that gearbox has a tighter spread from 2-3, 3-4, and 4-5 (23-27%). Those would be the gears you'd use and that box will give you a fair amount of flexibility.
Cons, cons...oh, yes, the cons. Well, I can think of four. First is that traction thing. If you hook up sooner, first gear is a little tall.
Second, the gap on the 1-2 shift of that box--2.66 to 1.78, over a 33% drop--is a little steep. Dropping the power a little further.
Third, fifth gear is along for the ride. With a huge 32+% drop between gears.
Fourth, if you modify the car, and more than a few should get header and cam upgrades, the power curve will continue climbing higher. The drop between gears will be significant, and that tall first and big 1-2 drop will be more of an issue.
Some of this may be mitigated by a little gearing legerdemain. A shift to a 3.73 or 3.90 rear gear should make this a complete 4-gear 1/4 mile car for a lightly modified (132 and 139 trap speed respectively) C6Z. Wow, it is hard to believe those may be numbers for a lightly modified car!
David
DavidNJ is offline   Reply With Quote
Old 02-07-2005, 08:51 PM   #2 (permalink)
Most of your facts are flawed.
2.66 1st gear with a 3.42 rear axle and a 325/30/19 tire will give a speed of over 60 at 7000 RPM
Old 02-07-2005, 10:28 PM   #3 (permalink)
You're partially right. I did have an error. The tire as a 325/25-19. However the combined change is neutral to the other calculations. Isn't math fun?
It would also mean the ratios to change to are a little different. It would need a 4.10 in a modified car to run through 4th in the 1/4 mile. And you may only get 125 in 3rd.
Otherwise...everything stands.
Old 02-08-2005, 08:27 AM   #4 (permalink)
0-60 is such a worthless measure it bugs me manufacturers bend over backwards to make their cars fast up to 60. Take a look at the new F430 speeds in gears...that is what the Z06 should have done.
Hey Rice Boy...a turd with a wing...is still a turd!
Z06Lover is offline   Reply With Quote
Old 02-08-2005, 09:27 AM   #5 (permalink)
I agree....the whole 0-60 thing is SO blown out of proportion...look at Subaru. From a roll, those things can be total dogs...but everyone quotes their 0-60 times. Hell, those WRX's only put down 170 hp to the wheels and they weigh 3,200+ lbs. 0-60 in 5.6 sec. doesnt tell the WHOLE story.
CHRIS
SC6311 is offline   Reply With Quote
Old 02-08-2005, 11:18 AM   #6 (permalink)
CHRIS
Absolutely!
Where lag dogs the turbo cars (there are Supra slips with a 5 second reaction time), the Z has a traction limitation. When does a 450-550 rwhp C5Z hookup?
David
P.S.
Z06Lover, one of the points is that the C6Z, at least a stock C6Z, is nowhere near as peaky as an F430. At least in stock form. So, making the gear spacing 20% or so will have less impact on acceleration. It would still enhance flexibilty a bit.
Old 02-08-2005, 11:21 AM   #7 (permalink)
I would much rather have a close ratio gear box that tops out right around 200 in 6th instead of a 5 longer gears because 6 is pretty much useless except for when cruising. This is a super car...who cars about gas mileage.
Old 02-08-2005, 11:29 AM   #8 (permalink)
Send a message via AIM to phantasms
no, 6th is just completely useless
a 5th to 160 or so and 6th to 205 would have been nice
06 Z06 Black/Black/Black/Black 1LZ-U3U-RC8 Mods: Exhaust switch - Bondurant Driving School - 345 Pilot Sports - Vette Doctors Air Charger - Tune =489rwhp 461rwtq 11.240 @ 128.5 w/ terrible 1.856 60' --- 03 Z06-EB/ModRed..traded in. Others:96 Grand Sport coupe #451-71 Vega 900hp 1800lbs
phantasms is offline   Reply With Quote
Old 02-08-2005, 11:32 AM   #9 (permalink)
I think you're forgetting about the Gas Guzzler Tax. Without 6th gear our tax rate would jump significantly.
Reboot is offline   Reply With Quote
Old 02-08-2005, 11:35 AM   #10 (permalink)
No, I didn't forget about it. The fact is you are buying a 65k+ car a little gas guzzler tax isn't going to make a dent in that amount of cash. Also, for the used market no one cares about it since it has already been paid. Is the C6Z06 competing against super cars or the prius??
Old 02-08-2005, 11:47 AM   #11 (permalink)
Send a message via AIM to Jay2002WS6
When you can have a great mix of both worlds, why wouldn't you want it?
Ever notice how most Ferraris have ridiculously low mileage on them? Well, you gotta wonder if they'd log a few more joyrides if you could accomplish better than 13 mpg on the highway in them.
I no longer drive a Cavalier.
Jay2002WS6 is offline   Reply With Quote
Old 02-08-2005, 11:50 AM   #12 (permalink)
i highly doubt ferrari owners don't take out their cars that often because of the gas costs. so the line of wealth goes civic, v6, vette, ferrari, suburban?
Old 02-08-2005, 12:55 PM   #13 (permalink)
I would add Tahoe in front of Suburban.
TetraU is offline   Reply With Quote
Old 02-08-2005, 12:56 PM   #14 (permalink)
Of course there are other factors, but I bet the cost of gas does come into consideration...
I just can't figure out why you guys are so against making this a well-rounded, complete, street car....
Old 02-08-2005, 02:13 PM   #15 (permalink)
Send a message via AIM to Chevy4Life
everybody's gotta have somethin to bitch about.
ELS
1995 Camaro Z28
K&N FIPK
Flowmaster American Thunder exhaust
Chevy4Life is offline   Reply With Quote
Pros and Cons of Track events sgiasZ06 C5 Z06 - Grandstand 18 06-15-2005 10:56 AM
Pros & Cons of Nitrous VNVETT C5 Z06 - Pit Road 4 04-04-2004 05:29 PM
are there any pros or cons for magnesium wheels? savage99ss C5 Z06 - Grandstand 5 03-23-2004 02:57 PM
Pros and cons of my new Z zul8r C5 Z06 - Pit Road 11 11-07-2002 08:55 PM
4:10's & 3:90's Pros and Cons Scott97 C5 Z06 - Pit Road 4 10-26-2002 09:50 AM
