Originally Posted by MSiska
Don't know what the TSB# is though.
Subject: Rear Axle Chatter Shudder on Turns - keywords differential fluid noise oil #PIP3559 - (09/22/2005)
Models: 1999-2006 Chevrolet Corvette
2004-2006 Cadillac XLR
The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern:
Rear axle chatter or shudder on turns on Chevrolet Corvette and Cadillac XLR.
Recommendation/Instructions:
If this is the first complaint for this condition flush and fill the rear axle with P/N 89021669 (in Canada 89021670) gear lube and 4 ounces of the friction modifier additive P/N 01052358 (in Canada 992694).
If this is a repeat complaint or the condition persists after the flush and fill, replace the right and left rear axle clutch packs following published service procedures.
After clutch pack replacement use 1.6 l (1.69 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455). and 4 ounces of the friction modifier additive P/N 01052358 (in Canada 992694).
Note: 2006 Z06 equipped vehicles require 2.55 l (2.70 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455) and approximately 190 ml (6.4 oz) limited-slip differential lubricant additive GM P/N 1052358 (Canadian P/N 992694).
Note: Export vehicles use 2.01 l (2.12 qt) synthetic axle lubricant GM P/N 12378261 (Canadian P/N 10953455) and approximately 150 ml (5.1 oz) limited-slip differential lubricant additive GM P/N 1052358 (Canadian P/N 992694).
Once the axle fluid has been changed the car must be driven in 8 - 10 SLOW figure eights to work the fluid between the clutch plates.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
