Old 05-07-2008, 06:45 AM   #1 (permalink)
383vett's Avatar
surge at part throttle
My 2008 Z06 with 400 miles has a slight surge at part throttle at constant speeds. If I'm in third gear at 35 mph on a level road and hold the throttle slightly open to maintain speed, the car feels like it's bucking or surging. Anyone out there experiencing this? Thanks
383vett is offline   Reply With Quote
Old 05-07-2008, 07:58 AM   #2 (permalink)
She's trying to tell you something. Mine does that also.
3 good Toyo T1Rs / CAGS Defeat / Tint / Soon to be Lowered / DEAD Braille, now --> Walmart Battery / Seat Bolster Mod / HPDE Checklist
Old 05-07-2008, 10:47 PM   #3 (permalink)
383vett's Avatar
Re: surge at part throttle
Thanks, good to know I'm not the only one with this problem.
Old 05-11-2008, 10:24 PM   #4 (permalink)
I am glad I am not the only one either. I also noticed the same issue. My particular case is that my car has been parked for about 4-6 hours after I started work. Then I go to lunch and I must maintain a speed of 30mph for a steady 2 miles inside a military base. During this 30 mph period(right after the car has been parked for 4-6 hours) the engine hesitates at partial throtle.
I think it has to do with not being arm up completely.
my .2c
08 Z06
Old 05-12-2008, 04:55 PM   #5 (permalink)
my .2c
Surging can be a lot of things but usually fuel/air ratio condition. Your car unless modified shouldn't BUCKING? That's pretty extreme. The LS7 will give a slight surge bone stock but not bucking. Mine slightly surges at low RPM's below 3000. I try to keep my cruising RPM's about 2500. When I FLOOR it there is no surge issues just low RPM in lower gears. If in doubt take it back to the dealer especially if it's bucking. Good luck to you.
Z06vette.com,NCRS/NCM
2006 2LZ LeMans Blue Z06.
65 GTO,69 Z/28,70 1/2 Z/28,
Old 05-12-2008, 05:18 PM   #6 (permalink)
383vett's Avatar
By "bucking" I meant a slight surge; almost as if the fuel is being shut off and on. It is very slight and barely noticable. It happends with the throttle barely cracked open. Apparently others are experiencing the same thing. Just a matter of semantics.
Old 05-12-2008, 07:48 PM   #7 (permalink)
Normal ops bud. Happy motoring.
2000 Rpm surge???? z06_23_45 C5 Z06 - Pit Road 8 11-17-2005 12:32 PM
Surge Tank SuperSportTruck C5 Z06 - Pit Road 5 10-13-2004 01:15 AM
Revs surge from idle when at operating temp... RC45 C5 Z06 - Pit Road 2 04-29-2003 10:08 PM
Surge Tank Pressure Cap fatherlarry FRC / Hardtops 3 01-07-2002 04:13 PM
Pedal chirp at part throttle? TITANS/Z C5 Z06 - Grandstand 7 07-30-2001 02:44 AM
