Old 11-14-2007, 10:37 AM   #1 (permalink)
STAGED47's Avatar
Tapping noise after header install?
After header install tapping noise now coming from the engine. No exhaust leaks but a loud tapping like a valve, not sure if you guys have that on your cars after the install? Or is the valve train just that loud? Thanks......
2006 Z06, LG Long tube headers, hi-flow cats
K&N Inkake system, HPE Stage 3 cam, ported tb.
583rwp 524tq
STAGED47 is offline   Reply With Quote
Old 11-14-2007, 10:47 AM   #2 (permalink)
Re: Tapping noise after header install?
Hi!
See if the headers or the x-pipe are hitting the tunnel plate when the engine torques over.
Just a guess, but been there- done that!
07 LMB Z w/ 0 mods except tune
485rwhhp and 455 rwhltq
Warp 10 is offline   Reply With Quote
Old 11-14-2007, 11:46 AM   #3 (permalink)
STAGED47's Avatar
Thanks, nope they are clear and the noise is coming from the header tubes. I hope its just a normal noise.
Old 11-14-2007, 12:14 PM   #4 (permalink)
Is it making noise at idle or when you let off the clutch at slow speeds?
BluZbrutha is offline   Reply With Quote
Old 11-14-2007, 12:19 PM   #5 (permalink)
robls6's Avatar
Not sure how loud your noise is, but it is normal to hear a "tinny" noise from the headers. Remember these are thin wall tube headers, not thick cast iron like the stock manifolds.
Old 11-14-2007, 12:25 PM   #6 (permalink)
PerforminNorman's Avatar
Could be just additional noise that you now hear with the headers since they are a thinner wall construction than the stock manifolds. If not, it could be a small exhaust leak.
Come to the Z06 Fest!
Performin' Norman
Old 11-14-2007, 01:05 PM   #7 (permalink)
RocketSled's Avatar
Could also be a bad gasket on the Header. There's nothing you could have done with the installation itself that'd cause an internal mechanical issue. It's got to be either exhaust noise or clearance between the Header and something external to the motor.
C6!
Old 11-14-2007, 02:31 PM   #8 (permalink)
STAGED47's Avatar
Thanks guys! It seems like the noise is most at idle and low rpms. Its seems to be running great I just want to see if anybody had this noise after a install.
New tapping/scrubbing noise (fairly loud)... 50thAnnivZ06 C5 Z06 - Pit Road 7 04-17-2006 01:56 PM
Cabin Noise after Kooks Install? BottleFed C5 Z06 - Pit Road 1 09-25-2005 09:58 PM
Question, Valve train noise with cam install shane C5 Z06 - Pit Road 15 04-20-2005 08:13 AM
Tapping / Rattling noise in Neutral w/ Clutch disengaged EB_Z C5 Z06 - Pit Road 2 09-23-2002 03:36 PM
2002 z06 engine tapping noise fredmonte C5 Z06 - Pit Road 15 05-16-2002 07:22 PM
