Originally Posted by Sirped
I was wondering if anyone else has heard a grinding sound while in first gear under slow acceleration? It goes away after getting up to about 2000 RPM. I only have 300 easy miles on the car. Thanks
Welcome to the site!
That is a normal noise. All the T-56's make that noise. You also may notice a slight "ticking" noise coming from the engine at low RPM's, very similar to lifters knocking, that is normal as well. I also believe some people feel shifter rattle while in the high RPMs (I do), and that isn't considered "problematic" either.
