Old 05-27-2005, 07:16 PM   #1 (permalink)
Transmission and AXLE ratios!
Was looking around at the website
http://eogld.ecomm.gm.com/NASApp/dom...page=6&butID=3
Specifically at the bottom of the Ordering/Mechanical section
and what do I see.
MN6 trans w/ GU6 rear.. 3.42 ratio.
You will see skilled drivers hit 0-60 in under 3.5 sec.
Jim
Jim Conforti is offline   Reply With Quote
Old 05-27-2005, 07:24 PM   #2 (permalink)
Yep, 2006 Corvette Z06 with MN6 manual and GU6 3.42 gears at 7000 RPM and 325/30/19 tires.
1 61.1
2 91.3
3 125.0
4 162.6
5 219.7
How significant are rear axle ratios? David Pintaric C5 Z06 - Pit Road 20 11-08-2006 12:49 PM
What differential ratios are available? Jim Conforti C6 Z06 - Pit Road 16 01-08-2005 01:37 PM
02-03 tranny ratios--someone with an 03 quikdoc C5 Z06 - Pit Road 2 12-02-2002 07:07 AM
What are the right AFR ratios Glenns C5 Z06 - Pit Road 2 11-17-2002 09:37 AM
Rear axle ratios.... GAGS Vendor Sales - C5 0 09-25-2002 06:10 PM
