Trunk Lights Problem / Not Working (Tried new bulbs) - Z06Vette.com - Corvette Z06 Forum
post #1 of 11 (permalink) Old 09-12-2012, 06:34 PM Thread Starter
JPSlick's Avatar
Hello
New member here. Let me start by saying I hate making new threads as I do try to do my due diligence and exhaust all search options before making a thread.
I can't figure out what is wrong with my newly purchased vette, C6 z06.
The trunk lights simply dont work. When I put in new lights they do not work either. I tested the connections with the volt meter and it appears to not be getting juice.
Is there anything I'm missing? Or do I need to start ripping off panels?
Is this a common failure point? Is there a module or switch that I can check?
Here is what I tried so far and cliff notes:
-New Bulbs, tried installing both ways.
-I checked every single fuse in the fuse panel under the passenger side compartment.
-Tested trunk lights with volt meter, not seeing 12 volts.
-The other interior lights still work.
JPSlick is offline
post #2 of 11 (permalink) Old 09-12-2012, 07:43 PM
Z06 Tech Advisor
racingvette's Avatar
Re: Trunk Lights Problem / Not Working (Tried new bulbs)
Try looking where the latch is as there is a single pole switch that the latch bracket in the hatch glass pushes down on
It could be the switch is stuck in the open position as if glass was latched down
Mike M - 2001 / 2008 Z06s
racingvette is offline
post #3 of 11 (permalink) Old 09-12-2012, 09:27 PM Thread Starter
JPSlick's Avatar
Thanks for the info. I'll take a look.
Let me ask you this...
Are the trunk lights supposed to come on when you open the doors?
OR only when the trunk is open.
Also, is it normal for the trunk to require some effort to close? I need to push down in the center area to ensure it closes all the way.
:eek2:
JPSlick is offline
post #4 of 11 (permalink) Old 09-12-2012, 09:38 PM
Z06 Tech Advisor
There is a light sensor so if sun is shining the lights would not come on if doors or hatch was open to prevent battery draw down.
Some people leave a window down just a bit so there is no pressure buildup when hatch is closed.
There is also a cabin air filter that would prevent pressure buildup
Make sure filter on passenger firewall is clean
post #5 of 11 (permalink) Old 09-13-2012, 08:11 PM Thread Starter
JPSlick's Avatar
Thanks.
I did some more testing. Now the trunk lights have 12 v going to both wires on the lights. Not sure if this is normal.
Anyone know how to locate a wiring schematic for the trunk lights? I googled for hours and cant find anything.
:eek2:
JPSlick is offline
post #6 of 11 (permalink) Old 09-15-2012, 07:03 AM
Originally Posted by JPSlick View Post
Thanks.
This may be too late, but here goes. This is an 08Z.
Ground 301 is also used by the fuel release door. Also, here's the lid pull down actuator schematic.
ID:	4384   Click image for larger version
ID:	4385   Click image for larger version
attherange is offline
post #7 of 11 (permalink) Old 09-15-2012, 08:25 AM
Z06 Tech Advisor
Drawing shows the lights get 12 volts directly and are switched by ground level at the hatch release switch
post #8 of 11 (permalink) Old 09-15-2012, 09:36 AM Thread Starter
JPSlick's Avatar
Yes, that is what I figured.
For some reason the lights are getting 12 V now and I checked the bulbs on a separate 12V and they get juice.
I guess it's not getting ground for some reason.
:eek2:
JPSlick is offline
post #9 of 11 (permalink) Old 11-28-2012, 05:03 AM
Hello
The trunk nice led lights simply dont work. When I put in new lights they do not work either. I tested the connections with the volt meter and it appears to not be getting juice.
You need to check wire connections are they working well?
Sayness is offline
post #10 of 11 (permalink) Old 11-28-2012, 05:51 PM
ZOHBABY's Avatar
:1_welcome: to the
'03 Black Z06
Corvette - Driven to be driven
ZOHBABY is offline
post #11 of 11 (permalink) Old 11-28-2012, 09:18 PM Thread Starter
JPSlick's Avatar
I finally figured it out. There was a loose pin inside the plug. Not sure how it happened but they work now. Thanks everyone.
:eek2:
JPSlick is offline
Reverse lights not working... VETTEST C5 Z06 - Pit Road 6 04-09-2008 09:05 AM
*QUICK QUESTION* what size bulbs are the front amber lights? DrtyHarry C6 Z06 - Pit Road 4 02-15-2008 08:26 PM
2 stock C5 head Lights with bulbs Amar1995 Member Sales/Trades - Parts & Cars 2 11-03-2007 11:02 AM
Actual LED tail lights for C5s. Not bulbs. Who makes these? Link inside marcus769 The Garage (non Vette related) 3 03-12-2006 06:04 AM
FRC Trunk lights FRC Tom FRC / Hardtops 0 02-13-2001 08:51 AM
