Anyone have any trouble getting the on board Universal Remote programmed? I have tried 40/50 times, including doing the reset/programming on my actual opener, all according to directions both in the z06 owner's guide and the garage door opener instructions, and still it won't work. Maybe I should ask has anyone got it to work? Any tricks?
I'm lazy. I had homelink in my 05 and my 06 and hadn't programmed either. Still have that bulky controller hanging from the visor. Thanks for the reminder. I'm going to get on it. LOL
Come to the Z06 Fest!
Performin' Norman
sometimes it has to do with your door opener... the new ones have a rolling code..
read the manual on the garage door opener not the homelink.. sometimes it will give you a hint...
__________________ First the banks.. now the car mfg's.. who is gonna bail out the Government. ??!
***i need a life**********
FEAR THE MIATA
thanks mike
Mike, what kind of garage door opener do you have?
Hey mike675,
It was a little tricky for me, too. Tried to program it one night and couldn't get it to work. Next morning, I realized the button-pushing sequence was ambiguous and tried it again. this time it worked and I've had no problems for a couple of weeks. My error was in releasing the second button and holding only the one I was programming whilst sending the signal. Read the owners manual again s-l-o-w-l-y and memorize the steps before trying again.
Hope this helps. Good luck.
Top Cog
2006 C6 Z06 MS, Ebony #5,889
wv and jim-I have a Quantum opener. It is a rolling code, but I had already tried programming it using the openers instructions, i.e. push program button, return to car a push URC button once while programming light on door opener is on. Still won't program and work.
top cog--re-read the instructions v-e-r-y slowly and followed them to a T. also tried the canadian programming (time out) and that didn't work either. I can't find anywhere where it says hold one button down after releasing the other, but I tried that also, it didn't work either.
Jim--thanks--I went into the homelink site and found my opener, Wayne Dalton-Quantum. It is compatible with homelink, so I guess I will call tech support at Dalton and GM to figure out why it won't work. I tried again tonight and still no luck. thanks again.
With rolling codes, I've always had to reset the "in car" unit, program the "in car" unit using the instructions provided, then.....
actually take a ladder, and access the button on the garage door opener mechanism itself that allows "button programming", and go through the steps on the mechanism as though you were programming a standard remote.
