Re: What is the spec for LS7 Oil Pressure?
I recently installed a cam into my new Z, my car at normal cold start start up makes about 60 PSI and drops to about 50 when its warm. After the cam install I didn't like the cam so I removed it, installed a smaller cam. Upon start up I noticed that the oil pressure on the dash was half of what it was. Thinking that I may have got a bit of crude in the oil pump that may have stuck the bypass valve, I replaced the pump, which netted the same results. So I tore it down again, removed the camshaft and mic'd the cam bearing journals and inspected the cam bearing. Nothing wrong was found, put it back together and measured the oil pressure at the front of the block where the oil galley has a port opening. At that point on cold start the engine has 65 PSI, but the dash reports half at 35 PSI. Later I replaced the sensor thinking it was bad, same issue, removed the intake manifold and installed a manual gauge there, low and behold the oil pressure is the same as reported on the dash and its low. When cold its about 35 when its warm it drops to 12 at idle but will raise to maybe 40 if rev'd up to 3500. I know it was OK, before the only other thing that was done during the cam and head swap was that the lifters was replaced with the GM Racing Cadillac performance lifters. I am now in the process of replacing them with the OE LS7 lifters in hopes of curing this issue. Has anyone else come across anything like this?
Before anyone asks if the oil pump is sealing to the pan, yes it is, that was checked over and over. Oil filter was also replaced.
