Old 05-16-2008, 08:22 AM   #1 (permalink)
Whirring Noise
Folks, I finally have my Corvette (2008 ZO-6), 500 miles and couldn't be happier. Unfortunately, I have an irritating whirring noise that appears to be associated with engine and/or transmission RPM, in all gears and with the a/c on or off. It increases with RPM and disappears when coasting at idle. Any ideas???
Diamondhead 26 is offline   Reply With Quote
Old 05-16-2008, 08:29 AM   #2 (permalink)
Whirring Noise
Multiple threads...threads merged
Old 05-16-2008, 10:10 AM   #3 (permalink)
DennyM's Avatar
Re: Whirring Noise
Congratulations on the C6Z and welcome to
Try a search on diff noise under C6 sub-forum.
Prolly just diff breaking in ...
rear axle chatter
Or CAGS-based ...
Dragging sound
DennyM is online now   Reply With Quote
Old 05-16-2008, 12:28 PM   #4 (permalink)
Re: Whirring Noise
Thanks, Denny! It sounds as it is coming from the front of the car. Probably too early to worry about. What a great website!!
Old 05-17-2008, 05:48 AM   #5 (permalink)
blhar15's Avatar
Re: Whirring Noise
I have the same sound associated with my car. I just figured it was a natural sound from a Z06. Does the oil sump system make any sort of noise?
Thanks
blhar15 is offline   Reply With Quote
Old 05-19-2008, 05:40 AM   #6 (permalink)
Re: Whirring Noise
Doesn't seem to.
Old 08-09-2008, 01:15 PM   #7 (permalink)
Re: Whirring Noise
Does it sound like this video?
Wierd Sound from Marv's C6
Mine does the same thing but only if I'm going downhill and I let go of the gas pedal. Here's another link you should look at:
DigitalCorvettes.com - whirring sound when shifting gears
Sorry I could help......... Fiddler50
Fiddler50 is offline   Reply With Quote
Old 08-09-2008, 02:51 PM   #8 (permalink)
itsaz's Avatar
Re: Whirring Noise
Pull the exhaust fuse! You won't hear it anymore, promise.
Z06Fest III,IV,V,VI,VII
Winterfest I&II
itsaz is online now   Reply With Quote
Old 08-09-2008, 05:05 PM   #9 (permalink)
Re: Whirring Noise
I've broken in alot of cars including my 08Z. There is alot going on and meshing in. I found my 08z to have had alot of noises while beaking in. I found by 3500 mls I had none of the original noises. Do a good break in and I mean proper break in for 500-1000 mls then slowly start having fun. It does take 1000 mls for the differential and trans to break in. Good luck sounds normal. Jim
Old 08-09-2008, 05:46 PM   #10 (permalink)
DennyM's Avatar
Re: Whirring Noise
Originally Posted by Fiddler50 View Post
......... Fiddler50
Welcome to , Fiddler!
Old 08-10-2008, 01:06 PM   #11 (permalink)
Re: Whirring Noise
thanks man.......... (My noise is definitely coming from the rear).
Fiddler50
Engine noise - not the typical noise GaryK C5 Z06 - Pit Road 10 01-11-2005 02:18 PM
1500 miles = NOISE NOISE NOISE ruper-z06 C5 Z06 - Grandstand 23 08-27-2004 01:58 PM
Odd whirring noise after track session? ylostrk C5 Z06 - Pit Road 12 05-01-2004 07:26 AM
Need Help...Bad noise from under car Prater C5 Z06 - Pit Road 0 05-26-2003 08:34 AM
