Z06 Clutch Fluid Change - Z06Vette.com - Corvette Z06 Forum
post #1 of 34 (permalink) Old 09-08-2009, 08:18 PM Thread Starter
:anyone:I need to change the clutch fluid in my 06 Z06 corvette. I need to know what fluid to use and if there are any instructions on this procedure. Thanks for the help!
Stupidcarjunky is offline
post #2 of 34 (permalink) Old 09-08-2009, 08:36 PM
Re: Z06 Clutch Fluid Change
Use turkey baster to remove fluid from reservoir, and replace with DOT3 brake fluid.
Check fluid color every month if not clear repeat above.
BlueZ06NY is offline
post #3 of 34 (permalink) Old 09-08-2009, 09:15 PM
Do a search for the Ranger method. It's also on the corvette forum. It's the easiest and best method.
seamus2154 is offline
post #4 of 34 (permalink) Old 09-09-2009, 07:53 AM
dwjZ06's Avatar
Location: Doing my time until I can leave this crappy azz liberal state.
Not correct. The fluid for C6Z's is Dot4 from the factory. You can pick up the GM stuff or there are a number of other DOT4's out there. Follow the Ranger method to keep it clean and fresh. Don
SIG by GR8 WHITE
dwjZ06 is offline
post #5 of 34 (permalink) Old 09-09-2009, 02:47 PM
DennyM's Avatar
Moved the thread to the C6Z pit road.
Don speaks the truth ...
DennyM is offline
post #6 of 34 (permalink) Old 09-09-2009, 08:10 PM
You are correct, I was thinking my C5 which they recommend DOT 3....DOT 4 would be my choice for brakes too, even though the C6 owners manual calls for only DOT 3...go figure! C6Z test cars at Milford had DOT4 in the brakes..a test engineers told me it was ATE
:gjob:
post #7 of 34 (permalink) Old 09-10-2009, 08:13 AM
DennyM's Avatar
A C5 that sees some track time with an owner who flushes/bleeds brakes and freshens clutch fluid regularly should run DOT4 in brakes & clutch as well. (I have since 2004)
A C5 that just sees street use is fine on DOT3.
DennyM is offline
post #8 of 34 (permalink) Old 09-10-2009, 11:57 AM
dwjZ06's Avatar
:gjob:
I used Dot 4 ATE Super Type II Amber color fluid for clutch and brakes. Don
SIG by GR8 WHITE
dwjZ06 is offline
post #9 of 34 (permalink) Old 04-23-2011, 11:11 AM
I am interested in doing this as well. I did a search for the Ranger method but cant find it. Can anybody please help with this? Thanks..
P_RsZ06 is offline
post #10 of 34 (permalink) Old 04-23-2011, 12:53 PM
pm sent
big al is offline
post #11 of 34 (permalink) Old 04-23-2011, 02:08 PM
YumaZ06's Avatar
Location: Yuma, Az. ?????? Z06 Fest IV, V, VII, VIII, IX, X, XII & Winterfest 1,2,3 & 4
Basically you use a "turkey baster" or "syringe" to suck out the fluid from the clutch reservoir.
Then use a lint free cloth or towel to remove the remainder of the fluid from the bottom. I use those blue mechanics paper towels.
Clean the cap and rubber thingy and refill with clean fluid (per mfr recommendations). I use Prestone Synthetic Dot 3 for my C5 Z06.
Put the cap/rubber thing back on and pump the clutch pedal 20 times and recheck the fluid.
If dirty again, repeat procedure until clean (you may have to do it a couple of times if real dirty).
Be aware that clutch/brake fluid is highly corrosive to paint and protect the car with rags around the clutch reservoir and be careful not to spill any on the car.
It should look like this when it is clean:
2004 MS/BLK
YumaZ06 is offline
post #12 of 34 (permalink) Old 04-23-2011, 09:14 PM
Thanks YumaZ06! I picked up a bottle of Prestone but am undecided if to use that or the GM fluid.
P_RsZ06 is offline
post #13 of 34 (permalink) Old 04-24-2011, 10:42 AM
Jim Lembo's Avatar
The Prestone brake fluid is fine. I've been using their DOT 4 synthetic in my clutch and brake systems in my C5Z for years. Don't waste your time and money looking for the GM stuff.
Jimbo
sig by GR8 White
'03 EB/mod blue, LME/V-Max 416, AFR 225's, Comp Custom cam from Pete at V-Max, 3" custom exhaust and lots of attitude! 10.47@133.38 :D Z06 Fest member III, IV, V, VI, VII, VIII, IX, X, XI, XII and Winterfests 1, 2, 3 & 4. 543rwhp/493rwtq, all motor!
Jim Lembo is offline
post #14 of 34 (permalink) Old 04-24-2011, 02:59 PM
I changed the fluid today. Very easy to do. But after pumping it i saw that it got a little dark. So I am sure I will be doing this again next weekend or even maybe during the week. It all depends on how dark it gets. To the OP, my apologies, I didn't mean to hijack the thread..
P_RsZ06 is offline
post #15 of 34 (permalink) Old 04-24-2011, 05:41 PM
wtxz10's Avatar
You need to suction it out. Replace it with fresh fluid, pump your clutch about 25 times fully to the floor and out. Check your fluid, suction it out, and do it again, until it clears up.
It took me almost 2 full containers of fluid before it got clear enough.
Please read Rules of the Road
wtxz10 is offline
Clutch fluid change (pics) hailskins666 C6 Z06 - Pit Road 30 04-14-2008 10:54 PM
Clutch fluid change questions. kmagvette C5 Z06 - Pit Road 9 05-03-2006 01:19 PM
How to Change Clutch Fluid? coopz06 Racing 7 06-20-2003 09:25 AM
How to Change Clutch Fluid? coopz06 C5 Z06 - Grandstand 3 06-19-2003 01:18 PM
Brake & Clutch Partial Fluid Change pmontelo C5 Z06 - Pit Road 16 07-12-2002 02:05 PM
