Vortech currently has superchargers available for 2005-'06 C6 with the automatic transmission and the 2006 Z06 (Tuner Kit for this vehicle).
4GS218-010SQ Vortech 2005-06 LS2 Corvette (Automatic Only) Silver Finish.. Complete kit with injectors, fuel system upgrade and handheld programmer
4GS218-018Q Vortech 2005-06 LS2 Corvette (Automatic Only) Polished Finish.. Complete kit with injectors, fuel system upgrade and handheld programmer
4GS218-110SQ Vortech 2005-06 Corvette LS2 C6 V-2 T-Trim Tuner Kit Satin**....**Tuner Kits do not include fuel management or engine management, which must be provided by the installer for proper engine operation.
4GS218-118SQ Vortech 2005-06 Corvette LS2 C6 V-2 T-Trim Tuner Kit Polished**....**Tuner Kits do not include fuel management or engine management, which must be provided by the installer for proper engine operation.
4GS218-120SQ Vortech 2006 Corvette LS7 Z06 V-2 T-Trim Tuner Kit Satin**....**Tuner Kits do not include fuel management or engine management, which must be provided by the installer for proper engine operation.
4GS218-128SQ Vortech 2006 Corvette LS7 Z06 V-2 T-Trim Tuner Kit Satin**....**Tuner Kits do not include fuel management or engine management, which must be provided by the installer for proper engine operation.
Gear driven, centrifugal supercharger with SQ technology provides nearly silent operation and unmatched reliability.
Technologically advanced, high-efficiency impeller and housing design developed in Vortech's supercharger test cell.
Supercharger drive system includes all necessary belts, pulleys, idler and tensioner.
High-flow bypass valve provides surge-free compressor operation.
Fuel management/calibration components used are high-capacity fuel injectors, high-flow fuel pump, fuel management unit (FMU), high-flow MAF, ECM chip or module, ECM re-programmer and timing controller.(The above items vary per application.).
Oil feed and oil drain assemblies deliver the best possible lubrication and cooling for the supercharger, even under sustained boost conditions.
High-flow air intake configuration with reusable air filter and specially designed inlet ducts for superior fit.
Inlet and discharge duct connections utilize heat resistant silicon sleeves and premium quality stainless steel clamps.
OEM-type cast aluminum or billet aluminum mounting bracketry for rigidity and a factory installed appearance.
Compatible with factory OBD II engine management systems.
Give us a call at 1-877-482-9763 or e-mail
tbyrne@tbyrne.com for current sale pricing.
Have a good day!
