Go Back   Z06Vette.com - Corvette Z06 Forum > Other Z06 Topics > The Garage
Old 04-23-2004, 07:22 AM   #1 (permalink)
Which jack from Harbor Freight?
I'm about to purchase the $89.99 version of the aluminium jack as opposed to their $130 version. Only diff. I can tell is that the cheaper one has an OVERALL HEIGHT of 8" and the other one is only 6.1", with saddle heights the same for both. Have you guys had trouble with the taller jack?
I'm going to use the pucks anyhow so I think my jack need not fit underneath the vehicle entirely. My Z is factory lowered. Thanks for any feedback.
bierry is offline   Reply With Quote
Old 04-23-2004, 08:42 AM   #2 (permalink)
DJWorm's Avatar
The jack you want is the Aluminum Racing Jack
Part# 47246-9VGA US General Aluminum Racing Jack
3000# Capacity, 35.4# weight, $129.99
as an option you can order it in different anaodized colors
as an additional option you can order it in a 4000# Capacity
Part # 2672-5VGA, 199.99
You can also jack from the side ala NASCAR style by using the triangular steel plate just inside of the rocker panel on the tunnel-rocker panel brace. This is located just behind the outside rearview mirror underneath the floor board.
CAUTION: DO NOT let the jack contact the rocker panel fiberglass or the floor board.You will not need jack pucks for this procedure.
This allows 2 side wheels off the ground at a time. Great for changing a tire, bleeding brakes etc.
Additionally jack stands can be placed under the frame rails at the shipping slots located just aft of the front wheels and forward of the rear wheels.
To place 4 jack stands you need to drive the 2nd lift side onto 2x12's for jack clearance on the 2nd side lift.
If lifting the front or rear you need the jacking pucks to spread the load on the Aluminum sub frame jacking points.
However a strategically placed 2x4 will sufice. Additionally you can lift both front and/or rear wheels by placing a longer 2x4 and jacking in the middle.
AMSOIL Online Store
Old 04-23-2004, 10:57 AM   #3 (permalink)
Dragon's Avatar
I've had the $89.99 jack from Harbor Freight ordered for about 3 weeks. Today I called to see where it was and they said it was on Back Order and couldn't tell me when it would be in so I cancelled the order. They had other jacks but ground shipping from California would take longer than I wanted to wait.
I turned around and ordered one from Jeg's for $149.99 and they said I would have it by Tuesday. It's No. 555-80032, aluminum, with a 47" handle, minimum height of 3.5" with a 14" lift and weight 37.7 pounds. It's only a 1.5 ton but lifting one wheel at a time shouldn't tax it too much.
"It's never too late to realize what's important in your life."
Dragon is offline   Reply With Quote
Old 04-23-2004, 03:49 PM   #4 (permalink)
Send a message via AIM to Rob1Vet
Hey Steve we have a harbor freight here !
Rob
Rob '02 M/Y ECS ATI D1SC, 600hp, 502tq
SOLD
Rob1Vet is offline   Reply With Quote
Old 04-23-2004, 03:51 PM   #5 (permalink)
Hey Steve we have a harbour freight here
Rob
Old 04-23-2004, 03:59 PM   #6 (permalink)
Registered User
I have this one. I had to bleed it before I used it the first time, so it would work. I think I need to bleed it again because it's not pumping like it should. They give you a little bleeders screw that replaces the regular filler screw. All you do is pump the crap out of it with the bleeder screw in place to get any extra air out.
X
Old 04-23-2004, 04:51 PM   #7 (permalink)
Dragon's Avatar
Rob
I ordered from them online and it happen to be California. I tried to buy one at the auto fair and the guy only had one for display.
Steve
Old 04-23-2004, 07:36 PM   #8 (permalink)
Steve
Hey bro
If you need anything from down my way let me know and it's yours !
Rob
Old 04-23-2004, 10:49 PM   #9 (permalink)
I just picked up a 3 ton jack combo from Pep Boys today for $99.00. It includes the 3 ton jack.......3 3/4" - 22". 2 of the 3 ton jack stands. 2 wheel chocks and a big kneeling pad. All comes with the combo for under $100!
I'll be trying it out on Sat. for my first oil change.
04 Z06 Mil Yellow Mod/Red - Donaldson Blackwing, Power Duct, Velocity Stack, Throttle Body By-pass, Hood Seal, Hurst Short Throw Shifter/Billiard Ball Knob, Eckler's Z06 Partition, Random Technology High Flow Cats and X-Pipe, 170 Thermostat, LS1 Edit, DuraStop Ceramic Pads and Drilled/Slotted Rotors.
HDRAMROD is offline   Reply With Quote
Old 04-24-2004, 09:55 AM   #10 (permalink)
Dragon's Avatar
Hey bro
Rob
Tickets for the 600!
Seriously Rob, I appreciate it and it was a pleasure to meet you and your wife.
Old 04-26-2004, 05:49 PM   #11 (permalink)
Hey the club is being asked to participate in the 600 and we get 2 free tickets !
Rob
Old 04-26-2004, 07:25 PM   #12 (permalink)
Dragon's Avatar
Rob
Is that 2 free tickets for each car? If so, where do I join?
I received my Racing Jack from Jegs today and it is a beauty. Now I can put on my powder coated wheels and new F1 Supercar tires since it is a very low profile jack.
harbor freight blackvetterzo6 C5 Z06 - Pit Road 8 08-21-2006 06:52 AM
Harbor Freight jack question-- War Eagle Z06 C5 Z06 - Pit Road 6 08-05-2004 01:47 PM
Harbor Freight jack owners--HELP! quickZ C5 Z06 - Pit Road 8 06-09-2004 11:19 AM
Harbor Freight racing jack owners--help! quickSS The Garage 3 08-23-2003 09:21 PM
Harbor Freight Tools Floor Jack? Zippy The Garage 16 08-17-2003 11:03 PM
» Auto Resources
» Sponsor Links
»Garage Storage and Cabinets
