Old 02-16-2008, 10:24 AM   #1 (permalink)
displacement on demand
Just for kicks, anyone enabled this in their LS7? HP Tuners appears to allow for this. I wonder what kind of gas milage improvement, if any? I am taking a long road trip in April and I was thinking of enabling it just for that. Any thoughts? Does it even actually work?
novaz06 is offline   Reply With Quote
Old 02-16-2008, 10:37 AM   #2 (permalink)
Re: displacement on demand
IIRC, DOD requires a different sprocket that has a "cam phaser" built into it.
As far as I know the LS7 doesn't have this installed from the factory.
I'm sure someone more knowledgeable than me will chime in on this soon.
I bet DJ Worm has the correct info about this.
Jimbo
sig by GR8 White
Old 02-16-2008, 10:15 PM   #3 (permalink)
It requires much more than that. Thus, quoting from an article at Superchevy.com....
DOD-specific hardware includes two-stage switching lifters, a lifter oil manifold assembly (located in the valley of the engine), a redesigned lube circuit and oil pump, electronic throttle-by-wire operation, a pressure-activated muffler valve, and an improved E40 engine controller running DOD-specific software.
"In order to eliminate the pumping losses, you need to disable both the intake and exhaust valve." This results in a completely sealed, deactivated cylinder, which is essentially an air spring being acted upon by a piston. Virtually all the work put into it during compression is returned to the crank during decompression.
"Currently, we could disable just the fuel delivery, but the valves would still be opening and closing and each cylinder would still be doing work pumping air in and out. So there would be no net gain in efficiency--you wouldn't have eliminated the pumping losses at all."
Old 02-16-2008, 10:47 PM   #4 (permalink)
AZZ061's Avatar
my 2006 SRT8 had the MDS on the motor made great for long trips as long as there were no inclines!
AZZ061 is offline   Reply With Quote
Old 02-16-2008, 11:24 PM   #5 (permalink)
I'm getting 19-20 MPG w/ my new GMC w/ this feature and I'm thrilled. 5.3 motor. I had an 01 w/ the 5.3 and got 13-14 nice improvement.
Back.. by popular demand G-Z06 Z06Fest / Performance Fest 21 04-16-2006 10:22 AM
Correct engine displacement??? nsxcorvette C5 Z06 - Pit Road 7 05-19-2005 04:22 AM
Big Displacement Header Diameter DavidNJ C5 Z06 - Pit Road 2 02-13-2005 07:13 PM
Get your order in now as demand will go SKY HIGH. Rick1 Member Sales - Parts & Cars 5 01-04-2004 05:50 PM
Supply & Demand!!! Rick1 Member Sales - Parts & Cars 2 03-26-2002 08:17 AM
