Old 03-17-2008, 10:22 PM   #1 (permalink)
Final Dyno run
I finally broke the clutch in and put it on the rollers. Very pleased with the results!
Intake port, custom cam, springs, pushrods, retainers, clutch, killer bee, B&B fusion, kooks
EudLose is offline   Reply With Quote
Old 03-18-2008, 07:01 AM   #2 (permalink)
Re: Final Dyno run
Nice #s... What are the cam specs & what was your baseline?
I have the same mods, other than the ported intake, Fusions & cam & I'm @ 481/454.
George B.
* '08 JSB Z06 11.4 @ 126 on EMTs, 481/454 SAE #s--some bolt-ons...
* '90 ZR-1 SGC built 368ci 'Factory Black Motor' (11.0 @ 130.2 & 11.2 @ 132.4) w/ the 368 (421ci Stroker coming!)--sprayed 120 shot.. 448 RWHP on motor, 560+ RWHP on the spray (SAE #'s)
Old 03-19-2008, 12:45 PM   #3 (permalink)
Re: Final Dyno run
Thanks. Smiles per mile are way up. They didn't do a baseline run because their dyno was needing some parts when I took it in.
The cam is a custom grind from comp cams. I'll have to dig out the papers to get the specs. Idle is a bit chunky like I wanted it to be, but it's very streetable.
Old 03-19-2008, 12:49 PM   #4 (permalink)
PerforminNorman's Avatar
Re: Final Dyno run
Way to go. Nice numbers. Thanks for sharing.
Come to the Z06 Fest!
Performin' Norman
Old 03-19-2008, 09:36 PM   #5 (permalink)
UVETTYA's Avatar
Re: Final Dyno run
Nice numbers Dave!
Steve
Black '04 Z06
UVETTYA is offline   Reply With Quote
Final 383 dyno graph. case2307 C5 Z06 - Pit Road 35 12-19-2004 05:18 PM
Final, Final sticking clutch pedal cure... RC45 C5 Z06 - Pit Road 7 11-09-2004 01:04 PM
GHL Long Tube Header Final Dyno Numbers... L.A. Performance Division Vendor Sales - C5 6 10-21-2004 08:10 AM
Final dyno #s after heads and cam install lajZ06 C5 Z06 - Pit Road 17 02-25-2003 05:26 PM
MTI 422 w/150shot final dyno #s No Mercy! C5 Z06 - Pit Road 28 04-26-2002 10:25 AM
