Re: "Help" Reduced power mode. "Throttle Actuator"
Sorry, I can offer little help, but I do have a few simple troubleshooting suggestions . . .
1. Check for any (engine related) blown fuses.
2. Disconnect and reconnect the cable to your throttle body.
3. Physically look inside the throttle body and verify there is no interference and freedom of movement of the actuator.
4. Replace the intake air filter (if you drive in a dirty air environment a lot, this should be replaced more ofter than recommended in the owners manual).
5. Have you modified you car, or retuned the PCM? If so, put it back to stock and see if this resolves the problem.
GOOD LUCK, and please let us know how things progress in resolving your problem.
