HP reduction need help - Z06Vette.com - Corvette Z06 Forum
 1Likes
  • 1 Post By racingvette
post #1 of 3 (permalink) Old 04-12-2017, 07:24 AM Thread Starter
Hi guys & gals I got a problem!. had a check engine light come on and I unhooked battery to reset light. Light went out and has not came back but seems to be less power than before. I took it to the garage and it has no faults to reset. Can it be running in reduced HP with no faults? Is there some way that I may have cut the power back like Mode or traction control ? thanks in advance Steve
sdgearhe is offline
post #2 of 3 (permalink) Old 04-12-2017, 08:18 AM
Z06 Tech Advisor
racingvette's Avatar
Re: HP reduction need help
Any time battery is pulled and reconnected causes the PCM to erase any DTCs and flush out all it learned like fuel trims, etc
Drive it to allow the PCM to relearn for a couple of days and then judge how engine is doing
If that DTC causing CEL comes back then you must look via DIC or OBD scanner what the code is, do not remove battery until that is done
bruce5793 likes this.
Mike M - 2001 / 2008 Z06s
racingvette is offline
post #3 of 3 (permalink) Old 04-13-2017, 05:34 AM Thread Starter
did not know it erased all. will do as you said and see what happens.
thanks for the advice. Steve
sdgearhe is offline
20 lb weight reduction ctdeng0 C6 Z06 - Pit Road 5 08-11-2008 08:49 PM
weight reduction??? socal guy Racing 32 12-20-2006 06:40 PM
Weight reduction... GranBichus C5 Z06 - Pit Road 21 04-13-2005 07:53 PM
Weight Reduction rsdonzi C5 Z06 - Pit Road 51 09-19-2003 04:49 AM
Weight Reduction rsdonzi C5 Z06 - Pit Road 0 09-15-2003 10:03 AM
