Got my LS7 tuning software today and thought I would share a little info.
Rev limiter all gears- 7100 rpms
Speed limiter all gears- 205 mph
PE table commanded AFR- 10.92-12.40 most of it in the mid 11s
Spark table- 18-20 degrees at WOT
42lb injectors @ 58 psi
Got a set of LGs on the way for the car I broke in back in Oct. Jack.
Next week I will get a new bone stock dyno (car now has 3-4K miles), tune it then dyno again, headers, tune and dyno again.
Also got a 2005 GTO 408 LS2 with a D1SC hitting 15lbs.
It's great to finally get all the Gen 4 software.
I just got the enhanced version interface and along with the LC1 wideband I will now be able to street tune and log AFR.
Also 1 and 2 bar enhancement for full speed density tuning.
Only need the dyno for #s now.
And for you LT guys the chip burner is on the way.
What kind of RWHP do you think it will produce?
My car is blue. My other car is red.
The car did 443 rwhp on the first pull with just over 500 miles on it. This was after a brisk break in from Atlanta to Tampa and almost straight up on to the dyno.
From what I see thus far, timing, afr, cot, and tq. management it looks like I should be able to pull 20+ just out of the computer.
Tom,
You're the man my friend!!! I'll be keeping an eye out for the results of that new Z your friend has. 20+ just out of the computer??!!!! Very
I'll get you to tune mine when I get it if you have time. Sounds like you are getting all the good stuff as well. I have yet to set a code with your street tune. Super job.
I don't know if I would trust a guy with 10 post on my tunning!
SIG by GR8 WHITE 2002 Quicksilver/Black (Sold)NCM Member.
He's like an odometer in an old car. Once you reach 100K she rolls over to zero again. Presto, you have a new car. Besides, Tom is like fine wine. Mellows with age.
