Old 04-04-2008, 04:04 PM   #1 (permalink)
LG pro headers +halltec gains (no tune)
Well. It has been only a week since I did the last bone stock dyno and since then I added the LG pro headers and the Halltec Air Filter.
The power went up from 456.72 whp to 470.44whp and the torque went up from 427.20lb-tq to 449.66lb-tq.
If you guys pay attention to the dyno in some areas the gains are about 33whp(in the lower rpm) and the torque is around 22lb-tq more in some areas.
I am running HFC cats so technically I could see even more gains. The car is not tune yet. I am definately happy. Last but not least I want to mention that remoing te fuse for the rear muffler buterflies made a huge difference in sound, hp and torque.
Here is my prior topic with stock dynos:
08 Z06 stock Dyno numbers(457whp/427lb-tq)
Here is the dyno:
08 Z06
Old 04-05-2008, 08:12 AM   #2 (permalink)
MikesZ06's Avatar
Re: LG pro headers +halltec gains (no tune)
Unfortunately, putting headers on the C6 Z has very minimal power gain. I've watched the dynos on a bone stock C6Z and then the comparison when adding 3 different headers (including LG's) and except for a little mid range torque gain, the rwhp increase was extremely nominal. Certainly not worth the money spent IMHO.
The good news is that just tells us how much improvement was made at the factory in the C6 exhaust manifold as compared with the C5.
Sounds like you picked up a few ponies with the Haltech intake though. That's the best power mod you can make on this car without going into the engine.
Now get that baby tuned and you'll see some nice power gains
9.87 at 141mph
& 2007 Black C6 Z06
Old 04-05-2008, 10:38 AM   #3 (permalink)
extanker's Avatar
i agree also the system is good enuf that it will be on the zr1
Old 04-09-2008, 06:27 PM   #4 (permalink)
The stock system is good... however, what you can get from a properly designed system (heads, cam headers) will always do better as a matched set. Getting that motor breathing better is always good. That is taking into account the changes in primary length, that needs to follow all other mods.
allgood57 is offline   Reply With Quote
Old 04-10-2008, 06:13 AM   #5 (permalink)
MikesZ06's Avatar
Adding heads and a cam is a totally different scenario than just adding a CAI and headers......
Old 04-10-2008, 02:37 PM   #6 (permalink)
My '06 picked up 27rwhp w/ LT headers & old school Halltech F1 filter element w/o a tune. I remember being shocked @ that gain, as the sentiment was that all the HP was in the tune, and minimal elsewhere. The tune only netted an additional 10rwhp after that.
It seems YMMV in this case...
George B.
* '08 JSB Z06 11.4 @ 125 on EMTs, 481/454 SAE #s--some bolt-ons...
* '90 ZR-1 SGC built 368ci 'Factory Black Motor' (11.0 @ 130.2 & 11.2 @ 132.4) w/ the 368 (408ci Stroker coming!)--sprayed 120 shot.. 448 RWHP on motor, 560+ RWHP on the spray (SAE #'s)
Old 04-10-2008, 06:43 PM   #7 (permalink)
MikesZ06's Avatar
Probably just a bad dyno
Old 04-11-2008, 09:15 AM   #8 (permalink)
We have also installed the LG longtube headders. But, we installed the vararam intake instead. Deleted the cats and have a tune for it. Just waiting to get it on the dyno. But from the seat of your pants you can deffinatly tell a diffrence in power. Atleast 50rwhp. And probably the biggest gain, or loss. Was the weight of the LG Headders was signicantlly less than the stock ones. about 20 pounds
06 Velocity Yellow Z06. Fest V, VI.
Screamin Z is offline   Reply With Quote
Old 04-14-2008, 10:12 PM   #9 (permalink)
Kiknss's Avatar
I thought I knew the set-up I wanted on my car till I joined this site!! Everybody has such different opinions about headers, intakes and exhaust systems. Wow. It's hard to tell what actually makes HP gains and what is just going to cost a lot of money and do nothing.... Thanks for the confusion. JK
JaKe
Kiknss is offline   Reply With Quote
Old 04-15-2008, 12:17 AM   #10 (permalink)
Send a message via AIM to CraZee ZO6
1st. Get tuned then you will see REAL GAINS. I say 490
About the comment on LT's not worth it on these cars, no I dont agree. Yes the stock system is pretty good but Longtubes are definitely better. The car will breathe and perform better.
On the dyno you may not see huge PEAK Gains in HP and TQ but under through the RPMS you will see a significant difference. Tuned you pick up great mid-range power
2003 C5 ZO6
STOCK LS6 346 cubes H/C
Vette Doctors RX500
498rwhp 427rwtq
CraZee ZO6 is offline   Reply With Quote
Old 04-15-2008, 07:31 AM   #11 (permalink)
MikesZ06's Avatar
Zee, how much mid-range rwhp and rwtq did you pick up on your C6Z with the headers? Also, curious about your peak gains?
Do you have your before and after dyno sheet handy? Would like to see your gains.
Thanks!
Old 04-28-2008, 09:32 PM   #12 (permalink)
dvredc6427's Avatar
As a new Z06 owner (as of 5/1 NCM delivery!!) I too am looking for the best HP/torque bang for the buck once mine is broken in. Dyno numbers are great but does anyone have 1/4 mile et's and mph for stock and then with mods? Have a friend with an 06 Z06 and after headers, intake and tune it ran slower at the track! He was really upset because his dyno sheets say he gained on paper. Anyone have both dyno and track numbers??
Thanks,
Del
08 Z06 427 #011 NCM delivery 5/1/08
dvredc6427 is offline   Reply With Quote
Old 04-28-2008, 09:43 PM   #13 (permalink)
chewbakkah's Avatar
were the weather conditions the same as he ran before? same track temp, same air temp/ moisture? that will have something to do with his times
forgive my ?'s i'm an information leech so to speak. i like to know as much about a subject as i can when going into something new. (except for the 5 years i spent at college)
chewbakkah is offline   Reply With Quote
ARH Headers + A&A Tune Greg Irvine C6 Z06 - Pit Road 11 11-16-2006 12:49 PM
C6 Z06 - LG Headers and Tune 494 / 470 Paradigm C6 Z06 - Pit Road 2 04-22-2006 08:08 AM
best and easiest lt headers, expected h/p gains? ANGRRRMGT C5 Z06 - Forced Induction & Nitrous 8 09-01-2004 08:16 AM
Gains from LPE headers WOW G Stamatakos C5 Z06 - Pit Road 10 06-28-2002 07:37 PM
Anyone put headers on their '02? If so what are gains? Search yield nothing. 02ZO6 C5 Z06 - Pit Road 24 05-04-2002 06:49 AM
