Old 04-27-2008, 12:12 PM   #1 (permalink)
bada's Avatar
LS7 ZO6 misfire ????
I installed a LS7 from a wrecked ZO6 in my 32 frod pro street truck. My ??? is I am getting a misfire code. Speartech did the PCM for me. I am running a turbo 400 auto tranny. I am running a weldon 600a fuel pump with a bypass regulator.PSI is set at 58. The motor idles fine, an seems to run OK. But the trouble light comes on. When we put a scanner on it to check codes it says misfire. Now before I got the motor, we went and listened to the motor run. It sounded fine. Any help would be appreciated.
bada is offline   Reply With Quote
Old 04-27-2008, 01:39 PM   #2 (permalink)
Re: LS7 ZO6 misfire ????
What year Corvette is the PCM from?
Send a PM to RC45, he installed a LS7 into his C5
Old 04-27-2008, 02:57 PM   #3 (permalink)
bada's Avatar
2008 ZO6
Old 04-27-2008, 05:09 PM   #4 (permalink)
GR8 WHITE's Avatar
Call me crazy, but the last MISFIRE I had, was a defective spark plug that wound up to be cracked. Since you installed the engine, is it possible a spark plug was cracked when you re-installed them? A simple check.....
Can't hurt to check it out..... Hope it is as simple as that.
Possibly a fouled spark plug wire or, when the wires were pulled off, maybe the wire itself was pulled and not the boot, so maybe the wire is frayed inside the shield and not 100% in contact with the boot connector anymore?
Just some suggestions....
Try new plugs and new wires. Are the spark plugs the correct ones for the LS7?
Good luck -
Old 05-03-2008, 02:45 AM   #5 (permalink)
extanker's Avatar
if you are using the z,s oem ECM it will tell you what cylinder is missing
Old 05-04-2008, 07:53 AM   #6 (permalink)
bada's Avatar
The misfire is not on any one cylinder. Its like a random misfire. Thats what has me stumped. I have solid motor mounts not like the factory ones with rubber in them. I am making new ones that I will have urethane in. I was thinking maybe the knock sensors were causing the code. PO300 is the code I am getting. IF the new mounts dont solve the problem I will be stumped for sure.
Old 05-04-2008, 07:55 AM   #7 (permalink)
bada's Avatar
Good luck -
The motor has the factory plugs & wires.
Old 05-05-2008, 01:03 PM   #8 (permalink)
extanker's Avatar
the emc might not be able to pick it up .like you said random. you are on the right track ,solid mounts can do it as can rotors,driveshaft and crankshaft position sensor relearn. good luck
Old 05-05-2008, 05:55 PM   #9 (permalink)
bada's Avatar
Thanks. I am getting urethane poured in my mounts now. I have customs mounts that we made just for the truck. So we modified them the accept the urethane. Hope that does the trick. If not the tranny mount will be next.
Misfire in 4th gear??? Help! Blue Angel C5 Z06 - Pit Road 24 08-12-2005 12:01 PM
What Would Cause A MISFIRE R/ZO6-LS6 C5 Z06 - Pit Road 4 02-17-2005 10:54 AM
Engine Misfire ??? Vrrooom C5 Z06 - Pit Road 10 10-30-2004 02:26 PM
Help - Possible Misfire Issue EnzoM C5 Z06 - Pit Road 9 04-21-2004 07:00 AM
misfire AJFZ06 C5 Z06 - Pit Road 1 06-22-2002 02:09 PM
