Old 08-04-2008, 08:41 AM   #1 (permalink)
spark plug recommendations !!
what do yall recommend. going with another plug or staying with the stock ones? my mods are in sig , the others mods i have done is vetteair and higflow cats . thanks
08Z06 Veloc. yellow. 490rwhp 452tq , K&N CAI , 160 stat, taylor race wires, HPtuner tune = 11:40 @126 mph (on stock tire)
05 SC-281 SALEEN #185 12:08 @115 just 4psi
Tune by LETHAL PERFORMANCE !!
08C6Z06 is offline   Reply With Quote
Old 08-04-2008, 08:23 PM   #2 (permalink)
I would run the same plugs I'm running right now - the NGK TR55s. The LS motors really like these plugs. Good luck.
Recent: 2003 Z06 BLK/BLK/BLK - GHL Exhaust | Zip-Tie Intake | NGK TR 55s | Nitto 555 RIIs. My BPP Shifter Broke In Two!!
Old 08-05-2008, 09:14 AM   #3 (permalink)
Re: spark plug recommendations !!
NGK TR55's are OK for street applications.
If you are going to track the car and want better reliability and performance switch to a Silver electrode plug. Silver has the best thermal and elecrical conductivity specs. Forget about Platinum, Iridium and Copper. and other mullti electrode gimmicks.
I recommend Nology Silver Racing Plugs, Part # G4YS or Brisk Silver Racing, Part # DR 17 YS. OR Beru Silverstones if you can find them (no longer made).
Note that the above NGK's, Nology's & Brisk need to be indexed for maximum performance.
The best racing sparkplug available is the Silver electrode Brisk LGS Premium Racing plug. This is used by Lamborghini and Ferrari. Part # DOR 17 LGS. This plug has a center Silver electrode and 4 recessed grounds. It does NOT need to be indexed. This plug offers the best 360* flame spread. I recommend this plug for maximum effort competition.
I recommend Magnecor KV85 Race Wires for non-Capacitive Discharge applications. These are the most reliable and low impedence wires available.
If you want to go with a higher performance CD wire I recommend Nology "Hot Wires". These must be grounded correctly. You may also want to consider installing Nology HD engine ground straps with this application.
Old 08-08-2008, 05:58 PM   #4 (permalink)
well i put ngk tr55s and the car didnt like it. the car would start bulking under part acceleration i guess running lean since its a hot plug. i then looked up ngk and it recommends the TR6s for the ls7, i then switched to tr6s and car runs awesome now. i have always used tr55s on my ls cars but i guess the ls7 likes a colder plug.
Old 08-08-2008, 07:37 PM   #5 (permalink)
Thanks for the info since I see vendors selling the TR55 for the LS7.
Old 08-12-2008, 08:03 AM   #6 (permalink)
427 Kid's Avatar
I dance with who brung me.
Stay with the Sparkplug the factory engineers deemed good.
Beware, Splitfire has resurected itself from bankruptcy and is selling their garbage again.
427 Kid is offline   Reply With Quote
Old 02-12-2009, 12:34 AM   #7 (permalink)
02SilverZ06's Avatar
Just finished putting some NGK Iridium plugs in mine an hour ago...TR-5IX with GM high performance red wires...not that it makes much difference or increases performance..but looks nice since they are red, and affordable. The drivers side rear plug was a real joy!
But purrs nicely now. had the original AC/Delco's...they looked horrible when i pulled them out.
02SilverZ06 is offline   Reply With Quote
Old 02-17-2009, 06:02 PM   #8 (permalink)
I like Denso Iridiums.
I ran them in my C5 Z and now my C6 Z.
Each to his own, but the numbers don't lie.
07 LMB Z w/ 0 mods except tune
485rwhhp and 455 rwhltq
Warp 10 is offline   Reply With Quote
Old 02-17-2009, 07:50 PM   #9 (permalink)
Ames's Avatar
I've always had good luck with Denso's and Taylor wires.
09 Z06 / 08 Z51 - www.RedC6.com
Ames is offline   Reply With Quote
Old 06-27-2009, 08:59 AM   #10 (permalink)
TR6 is the plug to run , I have used them on Turbo LS1/LS2s , The LS7 is a high compression pumpgas motor , i think the TR55 is a little to hot for the crapy gas we have at the pump !
Silver 2007 ZO6 , 475whp
Zone 3 peice forged wheels
Corsa cat back
K&N intake Danzio dyno Tuned
limeyZO6 is offline   Reply With Quote
Old 07-01-2009, 12:46 AM   #11 (permalink)
Stock is great..
Zeueses07Z06 is offline   Reply With Quote
Old 07-02-2009, 05:45 AM   #12 (permalink)
6speeder's Avatar
DJ: When you index the plug, are you "aiming" the open gap at the exhaust valve?
Porsches for breakfast
Ferraris for lunch
Old 07-30-2009, 01:55 AM   #13 (permalink)
Like what one of our buddies out there said, you should run the same plugs, the NGK TR55s..Lexus is compatible with these plugs. And if your not yet convinced, you can read some spark plug ang wire how-to manuals for your convenience.
Brandon Paul is offline   Reply With Quote
Old 07-30-2009, 08:21 AM   #14 (permalink)
Yes, single electrode plugs should be indexed with the "open" gap toward the exhaust valve.
This aids in correct flame front travel and orientation, fast burn and more complete burn with increased HP and less emisions.
Caution: When marking the plug to indicate the gap you must use a special dielectric marker, so as not to short the plug. Most normal markers have ink that will conduct electricity.
Both tapered and flat indexing washer kits are available, usually in 3 size ranges. Try Powerhouse products.
Old 07-30-2009, 08:35 AM   #15 (permalink)
Z0fritz's Avatar
DJ,
this might seem like a dumb question, but for indexing purposes, the open gap goes towards the exhaust valve, but is the open gap pointing up at the valve or down towards the piston. Basically, if you were looking at a clock and the exhaust vlave was on the upper right....would the gap point at 1 to 2 o'clock or 4 to 5 o'clock?
2003 Yellow Z06: Comp Cam, TI retainers, Halltech Venom, SVO 30# inj, Water/Meth injection, Katech ported TB, TB bypass, underdrive pulley, Kooks LT, BB bullet exh, No cats, RPM trans/diff 3.90, exedy twin disc, BPP shifter, dyno tuned...etc...
1969 Mach 1 big block being restored
Z0fritz is offline   Reply With Quote
How to gap a Spark Plug? bbullitt01 C5 Z06 - Pit Road 11 03-03-2008 06:58 AM
Spark Plug Gap? GRSZ06 C5 Z06 - Pit Road 2 07-04-2004 04:13 AM
Spark plug gap - Why so big? Slythetove C5 Z06 - Pit Road 8 08-06-2003 06:24 AM
MSD Plug wires and the proper spark plug gap MDVZ06 C5 Z06 - Pit Road 2 07-03-2002 06:51 PM
Spark Plugs.....any Recommendations? 01ZEE06 C5 Z06 - Pit Road 9 11-13-2001 09:51 AM
» Latest Auto News
» New Car Reviews
2011 Kia Sorento: First Drive
2010 GMC Terrain SLT-2 Review
