Go Back   Z06Vette.com - Corvette Z06 Forum > C6 Z06 Specific Topics > C6 Z06 - Forced Induction & Nitrous
Old 03-10-2008, 03:02 PM   #1 (permalink)
AFR Turbo Boost switch Settings?
I'm thinking between 10.5-11.5 should be fine with my low compression engine,
Any opinions?
rosulekg is offline   Reply With Quote
Old 03-11-2008, 03:20 PM   #2 (permalink)
ls6 boost control AFR?
Hey;
10.6-11.4 O.K.?
Thanks!
Old 03-12-2008, 08:44 AM   #3 (permalink)
LJo
LJo's Avatar
Re: ls6 boost control AFR?
10.6 is soft, 11.4 is a great place to be. How much boost and how much timing?
LJo is offline   Reply With Quote
Old 03-12-2008, 11:05 PM   #4 (permalink)
with 11.4 cr, I would not run much boost and or timing <6psi-7psi....
I was at 11.2cr and dropped down to 9.5 with 6psi making 585rwhp....
04 Torch Red Z06, TTi X Stage Twin Turbos, Patriot stage 2 ,062 Vinici cam, DTE Brace, LS7 Clutch, Rear Partition,V-1,Corsa Indy Cat=Back, T-Ported,3M Clear Bra,Chrome Z06 Wheels,Wilwood 6 Piston with GT Rotors.
jz06man is offline   Reply With Quote
Old 03-12-2008, 11:08 PM   #5 (permalink)
Re: AFR Turbo Boost switch Settings?
10-11 boost or cr.... whats your cr and boost, but imporant that boost id cr and rwhp.....Good luck!
Old 03-13-2008, 02:49 PM   #6 (permalink)
Here the deal guys:
My car was tuned at 7lb 9.5cr which is to much in lower gears so I am looking at lowering the boost without making it to rich and loading up the motor, and then switching up when I have traction.
Right now I'm thinking just running 11afr at 5.5lbs or so and 11.6afr with seven pounds using the 11afr as my reference when checking how the gas is doing.
Thanks!
Old 03-16-2008, 03:02 AM   #7 (permalink)
Look at a electronic boost controller like Exlie- you can set boost ramp rate an run all kinds of mulitple settings and set-up's.....
Fan settings TamVette C5 Z06 - Pit Road 1 09-27-2006 06:00 PM
AFR settings for PE/WOT? Cpig C5 Z06 - Tuning & Electronics 3 08-08-2006 10:38 AM
Turbo boost has a mind of its own? Ianz06 C5 Z06 - Forced Induction & Nitrous 14 12-05-2005 03:32 PM
NX TPS Switch & MSD Window Switch wiring help bonerben C5 Z06 - Forced Induction & Nitrous 1 06-22-2005 06:10 PM
C5R built for turbo boost Z06gman C5 Z06 - Forced Induction & Nitrous 21 04-13-2004 09:31 PM
