Go Back   Z06Vette.com - Corvette Z06 Forum > C6 Z06 Specific Topics > C6 Z06 - Forced Induction & Nitrous
Old 06-13-2008, 07:02 AM   #1 (permalink)
jrhunkler's Avatar
Supercharger Opinion > '08 Z06
Best superchargers currently? Do you have to change heads/cam etc to use one?
Also...
Has anyone installed a bottle in a C6 Z06 here? Is it safe for the engine? I know nothing about it, but would like to have an extra 100-200hp on tap. opinions? Best Systems? Easiest to use? Thanks.
jrhunkler is offline   Reply With Quote
Old 06-13-2008, 09:35 AM   #2 (permalink)
MikesZ06's Avatar
Re: Supercharger Opinion > '08 Z06
There are several blowers out there and most are quality products. You first have to decide whether you want to use a centrifugal blower (like Procharger or Paxton) or a roots type blower (like KB and Maggie).
Second, you have to realize your limitations with a stock LS7 engine. It has an 11.5:1 compression ratio amd non forged pistons. That means that boost, either from a blower or a nitrous kit, must be very tame.
There are several threads on this subject in the power adders sections so I will only hit the highlights....
If you do not want to lower your compression by porting out the combustion chamber of your heads, replacing oem pistons with dished or even using a thicker head gasket, then the amount of boost you run should probably remain under 6 lbs. If you install a meth kit, you can probably run the boost just a little higher.
If I were going to modify my C6Z, I would probably just throw on a Procharger P1-SC and run about 4.5 to 5 lbs boost. Except for injectors and a tune, additional modifications are not required.
The first C6Z that I saw MC Racing do that to, went to the track the day he got it back and ran a 10.8 on his first pass.
The setup I described above is very safe and should run around town like a stock set-up...until the extra power is needed.
If you want to go for bigger power, then some engine modifications are required...but that's a whole different subject.
9.87 at 141mph
& 2007 Black C6 Z06
Old 06-13-2008, 09:20 PM   #3 (permalink)
Look into the Procharger, like Mike recommends. Another alternative is the STS TT system. I think they had an article in Vette magazine where they had a C6Z with the STS kit. Good luck.
Old 06-13-2008, 09:48 PM   #4 (permalink)
jrhunkler's Avatar
Thanks!
After speaking with several different "pro's" today, Ive decided to stay away from voiding my warranty so soon... and I'm going to ad the following mods:
  • B&B Fusion Exhaust (already on it's way to me)
  • B&B X-pipe
  • BPP Step Headers
  • BPP Short Throw Shifter
  • Pfadt Sway Bars
  • Re-Tune
  • (I really want to upgrade the brakes, but the only significant difference I'm told is a full set of Brembo's which at $8k is pretty steep for a car that I don't track (yet, lol) >>> any advice on this would be great too. I think the factory brakes "blow" compared to some other high end sports cars. (I don't think I'm alone on this)
Then I'm "done" >>> ... she should have about 525rwhp by then... that should hold me over until the next body style comes out... which is when? 2011? 3 years is perfect... I'll get the C7 coupe and then I'll go nuts with twin turbo chargers / cam / heads / etc... (if I can't afford a Murcielago yet ;-)) Thanks again...
Old 06-13-2008, 09:52 PM   #5 (permalink)
If you want to have a little more fun with it, add a mild cam. Keep us posted.
Old 06-13-2008, 10:00 PM   #6 (permalink)
jrhunkler's Avatar
I would, but I don't want to void the warrantee. If I'm going to go with a cam, why go mild anyway? ;-)
Old 06-13-2008, 10:18 PM   #7 (permalink)
MikesZ06's Avatar
Originally Posted by jrhunkler View Post
Thanks!
  • B&B X-pipe
  • BPP Step Headers
  • Pfadt Sway Bars
  • Re-Tune
I'm not sure exactly where you come up with 525 rwhp with those mods??
I don't care one way or another whether you go with a power adder, but someone has led you astray if you think those mods you listed will give you that type of increase.
The only things you've listed that will give you additional giddyup is the tune and at most you will be in the 475-485rwhp range. The exhaust will net you 0 gains and the headers/x-pipe, I'm sorry to say will be very dissapointing too.
Don't get me wrong, there's nothing wrong with the mods you're contemplating, but except for the tune you have no real hp gains.
Old 06-14-2008, 02:40 PM   #8 (permalink)
Mild cam for driveability and reliability. Warranty? Who cares?
Old 09-27-2008, 03:49 PM   #9 (permalink)
Send a message via AIM to 08LS7SINY
And are you saying adding a sc or tt on a Z06 wont void your warranty?? :-)
08LS7SINY is offline   Reply With Quote
Old 09-29-2008, 08:30 AM   #10 (permalink)
jrhunkler's Avatar
Doing a custom twin turbo, AP 16" Brakes with 20"/19", I'll keep you all posted.
Old 10-01-2008, 10:47 AM   #11 (permalink)
K M
K M's Avatar
I didn't see this one coming. Good luck!
03 EB Z / 07 cbr600rr
K M is offline   Reply With Quote
Old 10-01-2008, 11:37 AM   #12 (permalink)
wvphoto's Avatar
yea..
mike has had good luck with his car.. it NEVER in the shop..LOL
but.. it is fast
***i need a life**********
FEAR THE MIATA
Need your opinion rocman The Garage 18 08-12-2005 09:15 PM
opinion of C6 dryforkz06 C6 Z06 - Grandstand 8 11-24-2004 07:47 PM
Only my opinion fatherlarry C6 Z06 - Grandstand 15 09-23-2004 04:41 PM
Your opinion on supercharger atz06 C5 Z06 - Forced Induction & Nitrous 12 06-11-2004 02:19 PM
Is this your opinion of BSM's?....... Maineiac C5 Z06 - Grandstand 14 02-20-2004 03:01 PM
