Go Back   Z06Vette.com - Corvette Z06 Forum > C6 Z06 Specific Topics > C6 - ZR1
Old 08-24-2007, 09:16 AM   #16 (permalink)
Cobra4B's Avatar
Re: The Mid-Engined Corvette is not only back on the front burner - it looks to be a
No Doubt... thank you for the detailed physics lesson in lehman's terms that I could easily understand.
Old 08-24-2007, 10:09 AM   #17 (permalink)
dwjZ06's Avatar
Originally Posted by proexpert View Post
A mid engine Chevy? It will never happen.
Steve,
Remember the Corvair from the 60's
SIG by GR8 WHITE
Old 08-24-2007, 10:39 AM   #18 (permalink)
panzer's Avatar
If we are going to break the mold of how things have been done historically with the vette I think mid engine is not the way to go. Let's just put a supercharger or twin turbos(my preference, let GM buy STS ) on a rear wheel drive setup. I cringe at the maintenance difficulties generated by putting the engine in the middle surrounded by bodywork. While they are at it they need to make it simpler to change out the clutch, removing 2/3 of the drivetrain to replace the clutch is dumb.
1985 BMW K100 m/c
Old 08-24-2007, 03:03 PM   #19 (permalink)
RocketSled's Avatar
No Doubt, I bow to your wisdom. You are truly knowledgable in the ways of automotive physics! Polar Moment. Of course. Same as a wheel. Same weight, different diameters, the larger diameter wheel will have greater inertia and take need more force to achieve a given acceleration.
If mid-engine gets all the mass closer to the spin-axis of the car, it'll turn faster. Du-uh.
C6!
Old 08-24-2007, 04:56 PM   #20 (permalink)
Jofu's Avatar
Yes, but that was exactly my point: The car's center of gravity does not correspond to the rotation of the car when the front wheels are steering, so in this sense it is _not_ the same as a wheel... ...or so I thought?
Interestingly, a few years back Jeep had come up with this concept car which had all-wheel steering, and it had this mode where all 4 wheels would point their axis towards the center of the car, and would allow it to spin on itself. _That_ car would benefit from a 50/50 weight distribution
Geoff
Jofu is offline   Reply With Quote
Old 08-24-2007, 04:57 PM   #21 (permalink)
Jofu's Avatar
Oh, and thanks indeed to No Doubt for all the cool explanations!!!
Geoff
Old 08-24-2007, 05:22 PM   #22 (permalink)
RocketSled was using a wheel as an example of how a rotating mass affects moment of inertia. The point was simply to explain polar moment of inertia and how moving a mass such as the engine either forward or backward affects it.
Remember, a cars CoG moves, both laterally as well as vertically. As the car accelerates, brakes or uses fuel the CoG shifts. Think of load transfer as an imaginary shift in weight, whereas weight transfer is an actual shift or relocation of a given mass in relation to the CoG and is what we are discussing in relation to a rear mid-engine car vs. a front mid-engine car.
The wheel example RocketSled gave is one whereby an actual weight is relocated toward or away from the center of a revolving wheel, not unlike the figure skater example I used.
Old 08-25-2007, 12:59 PM   #23 (permalink)
RocketSled's Avatar
Think of a big fly-wheel, mounted horizontally right in the middle of the passenger compartment (so it'd have to slice you and a passenger in half at the waist so you could fit in the car). That wheel has inertia, it requires force to get it to rotate. A mid engine car has all it's mass closer to the center of the fly-wheel, the fly-wheel is in essence smaller in diameter even though it still weighs the same. It's inertia is lower and it takes less force to get it to rotate.
Picture your car from above as it traverses a closed circle, say, like on a skid pad. As the car goes around and around, it is rotating on it's "Z" axis, the same axis as that big-ass horizontal fly-wheel example from above (the car's nose is always turning to point in the direction of travel. Viewed from above, the direction the car is facing rotates 360º for every loop. The car is in fact "spinning" at a constant rate as it goes around the circle at a constant rate!). The front wheels push the car in the direction of the turn, that is true, but the force they're exerting is battling the centrifugal force that's trying to push the car out of the turn.
So, when you change direction in your car, you need to rotate the car around it's Z-axis just like in the examples above. But unlike the situation above where the rate of rotation is constant, you must accelerate the car around that axis (first one way to initiate the turn, and then the other to cancel it out) to effect the change. It's the tires that generate the force to achieve that acceleration. So all other things being equal, the lower the car's inertia, the less force is required and the more quickly the car changes direction.
Old 08-25-2007, 01:18 PM   #24 (permalink)
RC45's Avatar
Which all amounts to a hill of beans if the 'new mid engined' Corvette becomes as single-use focused as a Ford GT or Lambo Gallardo.
Does the automotive world really need yet another "just like all the other" mid-rear non-allrounder supercars?
Old 08-25-2007, 02:45 PM   #25 (permalink)
Both cars depicted above could have a 50/50 weight distribution. That is, both cars could have the same weight over the front and back wheels depending on mass locations and weights. However, a rear weight bias is often preferable to a 50/50 weight distribution for the reasons discussed above.
Even if the car with the lower polar moment of inertia had a 50/50 weight distribution, it would turn faster since it requires less force to cause an acceleration: F = ma.
Bonus question: Can anyone tell me what size the tires are by looking at the drawings above?
Note: The size of the black squares merely represent a mass and are not relative to size or exact location.
Old 08-25-2007, 02:50 PM   #26 (permalink)
No, it doesn't. While I'm certain GM could make a mid-engined car that looks nice, it just doesn't sound Corvette-ish to me. One of the things I like most about vettes when I'm in them is looking out over that broad powerful and long hood. I suspect you'd give that up with a mid-engined design. A small thing perhaps, but important to me at least. It all sounds like change for the sake of change, not change for the sake of improving the blood line. I'd be happy to eat crow if GM proves me wrong.
Eric
97-137 Saleen S281 Cobra, 07-075 Parnelli Jones Saleen S302
2007 Corvette Z06, 2006 Harley Davidson Screaming Eagle V-Rod, 2008 Harley Davidson Rocker-C, 2007
snakecharmer is offline   Reply With Quote
Old 08-25-2007, 03:09 PM   #27 (permalink)
I agree with you in a way, Snakecharmer. As I've said before, I don't feel a rear mid-engine design would be of benefit to the Corvette demographic at this time.
The rear mid-engine design has benefits and it also has drawbacks, but aesthetics are not chief among them. However, aesthetics do play a role in how well a car sells, if it sells at all. A case in point was the Edsel. Although technically speaking it had features ahead of its time, it simply didn't go over well with buyers. Never mind the fact it was a POS and a Ford to boot.
I too may be eating crow but I just don't see GM totally changing gears, unless...
There may be some other motivation and/or outside force/s that compel them to change direction as far as Corvette design philosophy. I'm speaking of course about things such as future emissions and C.A.F.E. standards that may preclude the use of a larger, front engine, V8 design.
A smaller, lighter car with, dare I say it: something other than a V8 may eventually become a necessity. Then again, I was saying the same thing circa the mid to late 70's on the future of Corvette design. In fact, at one time I among others believed the Corvette would ultimately take the form of something akin to a (don't laugh) Pontiac Fiero or Sunbird.
Old 11-21-2007, 05:44 PM   #28 (permalink)
Oliveiraej's Avatar
I have had all variants, front, mid and rear engine sports cars. Each has it's issues and drive completely different. At then end of the day each car was fun to drive once I learned how to drive it. Front engine is the most familiar to everyone so the learning curve is easier. The rear engine car (911 Turbo) was the most difficult to learn how to drive since it is completely different from your normal reaction response. May current car a 1975 Pantera (Mid Engine) is great to drive but when it gets loose things happen very quickly. My favorite is the front engine, but it is not easy to go AWD with that configuration. If I had a choice of Mid engine AWD or Front not AWD I would choose Mid AWD. One last point right now the Pantera can carry luggage and a set of golf clubs with out any issues can't say that for any other current Mid engine car I've seen lately.
Ernie NJ 06 Z06 MTI
Stage II Extreme package
and a long list of goodies
Oliveiraej is offline   Reply With Quote
Rate This Thread:
Looking for GMID cert. Can anyone help? AMOK C6 Z06 - Grandstand 1 07-20-2006 07:04 AM
The Rotary Engined Chevrolet Corvettes GranBichus The Garage 0 10-13-2005 09:10 AM
They should have made the C6 Z06 Mid Engined andym C6 Z06 - Pit Road 27 12-01-2004 06:14 PM
Mid America one piece painted front turn signal grills edv2122 C5 Z06 - Grandstand 0 12-27-2002 08:34 PM
CERT® Advisory. rsherrard The Garage 3 03-01-2002 10:21 AM
