Go Back   Z06Vette.com - Corvette Z06 Forum > C6 Z06 Specific Topics > C6 - ZR1
Old 10-25-2008, 05:57 PM   #1 (permalink)
Exclamation People, Zr-1 Is A Gift To The Z0-6!!!!!
The zo6 is essentially a 5 speed....... 6th gear is just for gas mileage. A zo-6 with a zr-1 transmission will be a true six speed GUARANTEEING faster accelaration. And most importantly, maintaining the 50/50 weight distribution that the zr-1 DOESNT have.
Whaddayathunk?
nyege2 is offline   Reply With Quote
Old 10-25-2008, 06:07 PM   #2 (permalink)
MikesZ06's Avatar
Re: People, Zr-1 Is A Gift To The Z0-6!!!!!
Whaddayathunk?
Sorry bro, but I'm not sure how having 'true' 6th gear does anything for acceleration?
It may help the top end but I'm not sure exactly where you're going to need speeds in excess of 202mph?
Oh, and Welcome to the site!
Vette Magazine article
1/4 mile pass
Old 10-25-2008, 06:07 PM   #3 (permalink)
vant's Avatar
I think you stayed at a Holiday Inn Express last night.
Old 10-25-2008, 10:03 PM   #4 (permalink)
The '09 ZR1 has a sixth gear that is an overdrive gear with a ratio of 0.67:1, but unlike the Z06 its top speed is achieved in sixth gear.
The '09 Z06 also has an overdrive sixth gear with a ratio of 0.50:1.
Both use the same final drive gear ratio of 3.42:1.
Old 10-26-2008, 12:04 AM   #5 (permalink)
Thanks for the welcome. A 6th gear helps accelaration BECAUSE with an addition of an extra CLOSE ratio gear (thats not overdrive)it basically aligns all the gear ratios, that when u shift, the motor is never far way from its powerband. This is a TOTALLY no brainer here if u own a zo6. The zr-1tranny has a host of inprovements too like shorter throws, and more precise engagemets.If u own a ZO6, u honestly would be a fool if u didnt get this transmission for your slend.
Old 10-26-2008, 12:15 AM   #6 (permalink)
6th gear in the ZR1 is still an overdrive gear, but it's a lower gear than 6th in the Z06, which is also an overdrive gear.
The TR6060 transmission in the ZR1 uses the MH3 gearset, whereas the Z06, which also uses the TR6060, uses MM6 gears. Although the MH3 gearset offers closer ratios than those found in the Z06, once again 6th is still an overdrive gear. It's just not quite as high (tall) as the 6th in the Z06.
Now, look at the differences between 1st thru 3rd...
'09 ZR1 TR6060 gear ratios...
First: 2.29
Second: 1.61
Third: 1.21
Fourth: 1.00
Fifth: 0.81
Sixth: 0.67
Reverse: 3.11
Final drive ratio: 3.42
'08 and '09 Z06 TR6060 gear ratios...
First: 2.66
Second: 1.78
Third: 1.30
Fourth: 1.00
Fifth: 0.74
Sixth: 0.50
Reverse: 2.90
The ZR1s higher 1st - 3rd ratios are better suited to its greater horsepower and torque, whereas the Z06 is better off with its lower 1st - 3rd gears due to its lower h.p. and tq. and slightly higher redline rpm.
Old 10-26-2008, 07:58 AM   #7 (permalink)
proexpert's Avatar
There is no dash, please.
ZR1
Z06
no dash
Old 10-26-2008, 10:27 AM   #8 (permalink)
2MchFun's Avatar
The only dash is from 0-100
'04 MS/Blk - Z06Fest IV, V, VI, VII & VIII - WinterFest I "Bus Driver"
Old 10-26-2008, 02:45 PM   #9 (permalink)
First: 2.29
Second: 1.61
Third: 1.21
Fourth: 1.00
Fifth: 0.81
Sixth: 0.67
Reverse: 3.11
First: 2.66
Second: 1.78
Third: 1.30
Fourth: 1.00
Fifth: 0.74
Sixth: 0.50
Reverse: 2.90
Wow,...u work for g.m?
Old 10-26-2008, 07:04 PM   #10 (permalink)
I like getting good gas mileage in my Z06 with the double OD 6th gear ratio on the freeway. It also helps to cut down on engine and exhaust noise at correspondingly lower RPMs. Skip shift I could do without, but small price to pay for no gas guzzler tax.
Old 10-27-2008, 07:36 AM   #11 (permalink)
robls6's Avatar
In my opinion, the real gift that the ZR1 gives to the Z06 is that it lowers the price of Z06's a little bit. I am seriously considering upgrading from my 03Z to a C6Z and the lower prices definately make it attractive for me!
2003 MY Z06 - Lunati custom cam, LG headers, Blackwing, McLeod dual disc, RPM stage V trans
409 RWHP
Old 10-27-2008, 09:55 AM   #12 (permalink)
rainman750's Avatar
With ratios what they are, swapping a ZR1 tranny into a Z06 would HURT accelleration as the first 3 gears are ALL taller (numerically lower) with the same final drive ratio. So, please explain how this is a no brainer to swap trannies for C6 Z owners..............their car would be slower acceleration wise and on top of that would get worse gas mileage
2003 Procharged Z06 - Black on Black on Black - Tex Clutch - LGM Longtubes - BAP - 60lb Injectors - Lowered - Black Z06 Wheels - 580 rwhp daily driver
rainman750 is offline   Reply With Quote
Old 10-27-2008, 11:55 AM   #13 (permalink)
MikesZ06's Avatar
Rain, that can't be true because when I said something similar in my previous post, I was told... "This is a TOTALLY no brainer here if u own a zo6." and ..."If u own a ZO6, u honestly would be a fool if u didnt get this transmission for your slend."
Plus I was also given a quick lesson in how transmissions work
How cool is that!
Old 10-27-2008, 02:15 PM   #14 (permalink)
Have u ever4 shifted past the 3rd gear gear?? Life does exist past gear #3. If u dare to get out of your sub-division and hit the freeway, u might understand:pp:
Old 10-27-2008, 02:33 PM   #15 (permalink)
vant's Avatar
3rd gear goes well into triple digits, right? Those neighborhood kids wouldn't stand a chance!
Rate This Thread:
The Anniversary Gift! rpallas The Garage (non Vette related) 0 10-27-2006 08:36 PM
Gift Help Please SonofaZo6owner The Garage (non Vette related) 0 11-14-2004 10:48 PM
Got myself a gift GaryZ06 The Garage (non Vette related) 15 03-07-2004 09:41 AM
Going away gift for one of our own. z06nut The Garage (non Vette related) 16 02-23-2003 07:30 AM
Give a Gift to those in Need vetteluptuous The Garage (non Vette related) 0 12-19-2002 09:35 AM
» Latest Auto News
2011 Kia Optima Revealed Ahead of New York Auto Show Debut
Kia has just released a selection of photos of the all-new 2011
Report: Next Maserati Quattroporte Platform to Spawn Alfa Romeo Models
With a second-generation Maserati Quattroporte on the horizon, it now
Corvette Racing Video Series Part 1: Moving Past the Laguna Seca Crash
Corvette Racing has just released the first part of a 12 part series,
» New Car Reviews
2010 GMC Terrain SLT-2 Review
2010 Acura RDX SH-AWD
Acura's RDX is the only luxury crossover that delivers on its
2010 Lotus 2-Eleven Review
With the 2-Eleven, Lotus has built a track day superhero
2010 Audi A5 Cabriolet Review
The A5 Cabriolet is a great looking PCH-cruiser, but is rather
