Pratt Miller C6RS vs ZR-1 vs Callaway C16
Since before the ZR-1 was released, I posed the question, "who is the top dog?"
I'm sure I'm not alone. How can we make this happen? I'm tired of the comparisons of the GTR, Ferrari and Viper. I want to see these super siblings battle.
Who's with me?
Pratt Miller C6RS
Engine:
Katech Performance 8.2L C6RS
Type/Layout:
90 degree V8
Valvetrain Configuration:
Pushrod over head valves, 2 per cylinder
Displacement:
8.2 Liter (500 cubic inch)
Bore x Stroke:
106.8 x 114.3 mm (4.205 x 4.500 inch)
Compression Ratio:
11.0:1
Horsepower:
600 bhp @ 5800 rpm
Bhp/Liter:73.2
Torque:
600 lbs.-ft. @ 4600 rpm
Redline:
6200 rpm
Fuel Injection:
Sequential port injection
Recommended Fuel:
Premium unleaded
Component Features:
Block:
6061-T61 billet aluminum
Cylinder bores:
Liner-less Nicom coated parent aluminum
Main bearing caps:
Billet steel
Cylinder head:
LS7 production sand cast aluminum
Crankshaft:
Forged 4340 steel
Connecting rods:
Forged steel, special alloy
Pistons:
Forged 4032 aluminum
Callaway C16
o 650 bhp* 6.2 liter (378 cu.in.) V8, 90°, cast aluminum block and heads; 6-bolt cross-bolted main caps
o Supercharger- Eaton/Magnuson TVS Roots-type; with air/liquid intercooler integral to intake manifold. 52" Hg manifold pressure, absolute or 10 psi, gauge)
o Bore x Stroke: 4.060 x 3.622 inches
o Compression ratio: 10.1:1
o Torque 600 lb-ft* @ 4,750 rpm
o Redline: 6,500 rpm
o Fuel system: Increased flow fuel injectors; auxiliary fuel pump controller
o Ignition system: coil per cylinder; Callaway UHC-8 sleeved silicone ignition wires
o Throttle body: 90mm diameter, drive-by-wire
ZR-1
Y'all should know the specs by now.
