Go Back   Z06Vette.com - Corvette Z06 Forum > C6 Z06 Specific Topics > C6 - ZR1
Old 12-22-2007, 05:41 AM   #1 (permalink)
spdrcrj's Avatar
Weight and tranny
Why is the new ZR1 so heavy? I know it went up an inch in tire size front and back but the lighter rotors should have compensated for that at least a little bit.
Also, I read that the tranny is built to handle the power. Does it have the T6060 of the Viper?
Disregard both questions.....I did more research and found my answers. This car is far more than a souped up Z06. It's a built supercar, ableit with leaf springs.
Old 12-22-2007, 02:44 PM   #2 (permalink)
Re: Weight and tranny
The leaf spring design, as used in the Corvette, is actually superior to coilovers in some ways.
If you don't think so, then ask Reeves Callaway*, or ask Pratt & Miller why they didn't use coilovers on their C6RS. And I'm not just saying that. I'm serious. Call them and ask.
After all, we're not talking about the stacked leaf spring design found on a truck.
*"We do not put the full spring loads of the suspension through the shock towers. First they were not designed to carry those loads, and second, we used to do that with our earlier versions of the Coil Over theory of how to make a Corvette handle well. Long term, it was not a success."
Old 12-23-2007, 10:38 AM   #3 (permalink)
Yea but if you listen to the Euro mags the leaf spring has gone way of the ox cart. The leafs seem to work IMOP,but I am not an expert like the euro mag are.
Sky1 is offline   Reply With Quote
Old 01-01-2008, 02:30 PM   #4 (permalink)
painrace's Avatar
Supercharger and upgraded drive line parts add the weight. However, 3344# divided by 620 HP = 5.4#/HP! The 620 HP is with a J-1349 correction factor. If you use the J-607 correction factor (the one aftermarket advertisers use) the HP will go up 30-35 HP. 3344 divided by 650 HP = 5.15#/HP. My Katech Z (which I will keep) weighs 3155# and the weight to HP ratio is similar to the ZR1 depending on which correction factor you use. But, I think there are a lot more good things to come out about the ZR1. Maybe Zippy will give us all a ride when he gets his? Maybe he will at least let us look at it?
Please Mr. ZIPPY?
Jim
Painrace
painrace is offline   Reply With Quote
Old 01-01-2008, 02:55 PM   #5 (permalink)
That hits the nail on the head, IMO. As I've stated here before, I feel the ZR1 is essentially a public test mule of sorts. Technology used in the ZR1, supercharging for example, may likely find its way into future Corvettes, starting with the C7. We already know from seeing the GM LSx roadmap that most future LSx engines are going to employ supercharging. In addition, I wouldn't be at all surprised if the C7 is E85 compatible. In fact, I wouldn't be surprised if the ZR1 also turns out to be E85 compatible as well. Since Ethanol blends are a higher-octane fuel, forced induction can benefit from it (fewer cubic inches + more boost = less weight along with increased hp and fuel mileage), so it only makes sense.
Think of it as an evolutionary change. Remember, Mitsubishi already had the same idea.
Old 01-01-2008, 05:56 PM   #6 (permalink)
painrace's Avatar
How do you get the less weight? Super charged engines are heavier and taller and neither are good for performance cars today. Maybe with improved supercharging technology but not today. The Ferrari engine is so tall it must go behind the driver!
Also, E85 is more expensive to produce that gas. I don't see how that is going to change. It is only successful today because of government subsidies. However, GM and Katech both have powerful e85 engines.
Jim
Rate This Thread:
Ls1 Weight vette6autox C5 Z06 - Pit Road 7 09-11-2006 11:43 AM
Weight of the Z06? itchynackers C5 Z06 - Pit Road 12 08-30-2004 08:24 AM
How much weight savings from non-pop up headlights?? Light weight battery results?? Silver Bullet C5 Z06 - Pit Road 16 01-23-2003 10:25 AM
Want to swap Z06 tranny for "regular" C5 tranny? Redshift C5 Z06 - Grandstand 48 12-04-2002 05:57 AM
What Is Your Height And Weight? Ladies May Skip The Weight Part..... AgentZ06 The Garage 85 09-29-2002 07:48 AM
