Go Back   Z06Vette.com - Corvette Z06 Forum > C6 Z06 Specific Topics > C6 - ZR1
Old 05-31-2008, 10:30 AM   #1 (permalink)
zr1 carbon fiber paint
Hey I was reading up in Corvette quarterly how the paint that coats the carbon fiber pieces on the zr1 costs something like $60,000 a gallon. Is this true or am i just crazy because that is insane!
paulyd04 is offline   Reply With Quote
Old 05-31-2008, 03:58 PM   #2 (permalink)
pauln64's Avatar
Re: zr1 carbon fiber paint
according to this...it's $2000 per gallon
Taking a look at the 2009 ZR1 Corvette - Vette Magazine
Old 05-31-2008, 09:03 PM   #3 (permalink)
$2k a gal.
Old 06-01-2008, 10:13 AM   #4 (permalink)
pauln64's Avatar
on a lighter note...soon, that's how much gas is going to be
Old 06-05-2008, 05:14 AM   #5 (permalink)
NCM Ambassador
Zippy's Avatar
They use a very slight amount in the paint. From what I've heard it's an additive to the paint or clear coat.
Zip
Old 06-05-2008, 11:01 AM   #6 (permalink)
pauln64's Avatar
although it's a nice visual cue, I say skip it and put the money somewhere else. After I thought about it, is BMW doing the same thing with the new M3 since it has exposed CF roof? If it does, I hadn't heard anything about them using the same additive.
Old 06-05-2008, 03:15 PM   #7 (permalink)
I thought I heard it was a necessary thing, or else the panel/material would deteriorate with time under the sun. Could be wrong though!
Provided my above statement is true, maybe BMW *is* doing the same, but they chose to enphasize a different part of their car, instead of talking about some silly paint or clearcoat
Geoff
Jofu is offline   Reply With Quote
Old 06-05-2008, 04:28 PM   #8 (permalink)
All of the best clear coats have a UV protectant in them . Thats what separates them from a cheaper clear coat. The cheaper ones have none. I just bought DBU clear from PPG for my 70 GTO project because it has UV protection and it was quite a bit more money than others with none. I'm sure the ZR! stuff is super UV for that price! Now living in South Florida I see how the sun kills everything that isn't protected down here. So I'm quite sure the Carbon fiber would deteriorate after some time.
Old 06-05-2008, 08:05 PM   #9 (permalink)
All carbon fiber has some kind of coating. There's the good stuff and the stuff that yellows with exposure. I doubt the M3's roof will yellow - they wouldn't cut corners like that.
Old 06-06-2008, 11:18 AM   #10 (permalink)
DJWorm's Avatar
Exposed CF has to be protected from the full spectrum of UV light; A, B & C modes in the UV spectrum or else it will break down the fibers AND the resin will delaminate and degrade as well.
Here's a clarification of the costs associated with the Carbon Fiber clear coat on the new ZR1
The full spectrum UV blocker used in the clearcoat is Nano-technology based.
The Nano technology base IS $60,000.00 per gallon.
When the Nano-technology full spectrum UV blocker base is added and mixed with the appropriate clearcoat it produces a full spectrum UV blocker clearcoat which is $2,000.00 per gallon.
About 1/2 gallon of the nano-technology full spectrum UV blocker clearcoat is used to finish a ZR1 roof. Thus the net cost to paint a ZL1 roof is about $1,000.00 per vehicle.
It will be interesting to see what a body shop repair bill will be if there is any damage to the CF roof panel. I just wonder if a body shop will be able to buy the clearcoat in 1/2 gallons. I would also wonder if some body shops will cheat and use a non UV blocker clearcoat. I,m sure the insurance Co's will possibly try and force them to use a less expensive clearcoat. SO....if your roof panel gets damaged and is repairable; pay close attention to how it is repaired and varify that the correct clearcoat is being used in the repair.
AMSOIL Online Store
Old 06-06-2008, 11:35 AM   #11 (permalink)
Great info DJ
However the part about 2 quarts of clear being used to paint the top of a ZR1 is very hard to believe. Even one quart would be a lot. What is your source of this information?
Old 06-06-2008, 02:49 PM   #12 (permalink)
pauln64's Avatar
also, remember that the front spoiler and the rocker panels also have the CF with the same clear coat...I'm sure that'll be a pain to maintain.
Old 06-06-2008, 08:45 PM   #13 (permalink)
Originally Posted by IT L GO View Post
Great info DJ
After reducer and hardener you almost have double the original amount. That depends on the ratio 3;1;1 or 4;1;1. Two quarts of clear could do almost a whole car!
Old 06-12-2008, 08:58 PM   #14 (permalink)
dvredc6427's Avatar
It might be expensive but after seeing the ZR1 in person twice now (both cars were the dark grey color), the clear coated carbon fibre looks awesome and is a nice touch to what is supposed to be a "Supercar". I'd pay a few thousand more to have it on my 427 for sure if I had the option. Just my opinion of course...and photos don't do it justice.
Del
08 Z06 427 #011 NCM delivery 5/1/08
dvredc6427 is offline   Reply With Quote
Rate This Thread:
Carbon Fiber anyone? phantasms C5 Z06 - Pit Road 10 06-10-2004 08:50 AM
Paint and install Carbon Fiber Louvered Hood silverfox C5 Z06 - Pit Road 0 06-03-2004 10:43 AM
Paint on Carbon Fiber Hood 03Z06VETTE The Garage 6 03-25-2004 03:34 PM
carbon fiber JtownZ06 The Garage 2 07-16-2003 09:12 AM
carbon fiber corvette184 Vendor Sales - C5 13 01-16-2003 08:48 AM
