Go Back   Z06Vette.com - Corvette Z06 Forum > C6 Z06 Specific Topics > C6 - ZR1
Old 04-25-2008, 03:24 PM   #1 (permalink)
El Calor's Avatar
Send a message via AIM to El Calor
ZR1 Tops out at 205 mph!
New Corvette ZR1 Tops Out at 205 MPH - Brightcove
El Calor is offline   Reply With Quote
Old 04-25-2008, 03:38 PM   #2 (permalink)
Re: ZR1 Tops out at 205 mph!
Whoa. I've never been that fast except in a video. Thanks for posting.
chjw is offline   Reply With Quote
Old 04-25-2008, 04:10 PM   #3 (permalink)
Awesome!!!!
Sky1 is offline   Reply With Quote
Old 04-25-2008, 05:57 PM   #4 (permalink)
GR8 WHITE's Avatar
Nice.... Where do you think that was video taped? There were two other vehicles on the road during that test? One was a truck. Was it open road or a track where they test MACK TRUCKS too.
Second, does anyone else think it took quite the time to reach that speed? The 996 I raced in Germany hit 206 mph and I don't think it took nearly as long to reach that speed.
(trust me, I know as I seen his tail light dim rather quickly)
Still impressive!
Old 04-25-2008, 06:21 PM   #5 (permalink)
That test was conducted at a proving grounds in Papenburg Germany called ATP (Automotive Testing Papenburg, GmbH) on this high speed oval...
http://inet.atppbg.de/images/stories...alrundkurs.pdf
Here is the tracks website...
ATP Papenburg - Home
Old 04-26-2008, 01:04 AM   #6 (permalink)
RC45's Avatar
Am I imagining or did he down shift form 6th to 5th - then do the run from 100mph in 5th, and short shifted to 6th at about 165mph... then ran 6th to 200+?
I guess that will dispell myths about 6th gear being an overdrive not meant for high speed then.
I wonder if the real "time to 200mph" runs will need to be made in 5th gear.
Old 04-26-2008, 10:29 AM   #7 (permalink)
GR8 WHITE's Avatar
Thanks Thats quite an impressive proving ground oval. I was wondering why he felt that confident to keep the gas pedal pegged in th ecurve. Too bad we don't have any proving ground over here except Interstate 10.
Old 04-26-2008, 12:34 PM   #8 (permalink)
Very cool.
Old 04-27-2008, 11:05 AM   #9 (permalink)
Originally Posted by El Calor View Post
Doesn't the stock LS7 Z06 top out at 198 mph? If so they must have a speed limiter on the ZR1.
Z06vette.com,NCRS/NCM
2006 2LZ LeMans Blue Z06.
65 GTO,69 Z/28,70 1/2 Z/28,
Old 04-27-2008, 12:06 PM   #10 (permalink)
Yes, the official top speed of the C6 Z06 is 198 mph. The ZR1 is governed (limited) to 210 mph.
Old 04-27-2008, 04:44 PM   #11 (permalink)
QSATL's Avatar
Yes, six gear is not overdrive in the ZR1, it is direct drive jest like the other five gears. It is top speed governed at 210.
QSATL
QSATL is offline   Reply With Quote
Old 04-27-2008, 05:20 PM   #12 (permalink)
That's not true. Fifth and sixth are in fact overdrive gears...
ZR1 gear ratios:
First: 2.29
Second: 1.61
Third: 1.21
Fourth: 1.00
Fifth: 0.81
Sixth: 0.67
Reverse: 3.11
Final drive ratio: 3.42
Source: 2009 Corvette ZR1
Rate This Thread:
how to clean convert. tops?? COUTO1981 C5 Z06 - Pit Road 3 04-04-2005 03:59 AM
Z06 Tops? RobSan The Garage 2 09-05-2004 05:55 PM
Don't you wish your Z had Tee Tops? z06nut The Garage 11 10-13-2003 10:01 AM
Jacks & stands Flat tops Fish-man C5 Z06 - Grandstand 4 10-30-2002 07:11 PM
F/S: VetteNet for drop tops jdZ06 Member Sales - Parts & Cars 0 10-14-2002 01:24 PM
